Thread: Rear end noise?
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: Rear end noise?
    Antioch, IL
    Quote Originally Posted by WarStryker13 View Post
    That's what happens when you listen to a corey...
    I am gonna guess walmart pin point head jack? Mines been face down ass up plenty of times with no ill effects. A block of wood would help your 04+ next time.
    2009 Challenger SRT8
    Expert at being gay.
  2. #22 Re: Rear end noise?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    No idea, was there before I got it.
    I use the pinch welds, mine are still good shape.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #23 Re: Rear end noise?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    That looks more like they hit something. Weird. That is a clean underbody!! I've seen nothing like that here unless it was parked in the winter, or undercoated from the start.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  4. #24 Re: Rear end noise?
    Sep 2015
    Lansing, Michigan
    So with the car on the ground I reached around the wheel and grabbed the end link and it started moving around up and down and making a clunking noise. So looks like that's my culprit. Are junkyard ones any good? I gotta go there tomorrow to get some parts for my mom's car.
  5. #25 Re: Rear end noise?
    Oct 2014
    Frederick, MD
    Not likely. Just order some from RockAuto.
  6. #26 Re: Rear end noise?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by tom5170 View Post
    Also, should I remove the nuts on the strut tower first, then jack it up?
    I did my rears recently and what worked good for me was to loosen the upper nuts, but leave them on a couple turns, then jack it up to stands, then work the bottom off, then reach in the trunk and spin then off.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  7. #27 Re: Rear end noise?
    Antioch, IL
    It took you 26 posts to realize what someone said on the 2nd post? Why would you go to a junkyard for a maintenance item, I hope you dont get your ball joints there.
  8. #28 Re: Rear end noise?
    Enfield, CT
    any way to check them? do I need to jack up the entire back end at once? or can I just do one wheel at a time?
    where's the best place to jack it up at? I live in the rust belt so my pinch welds are a little weak.
    crawl under car, grab rear sway bar as hard as you can and push up on bar to reduce load on end links and as you are pushing up the bar, grab end-links and wiggle them to see if there is play.
  9. #29 Re: Rear end noise?
    SE Level Member jmartell's Avatar
    Jan 2016
    Centre Wellington, Ontario
    Quote Originally Posted by HighOctaneRacing View Post
    it would appear hes got it sorted.....
    Lack of planning on your part does NOT constitute an emergency on my part.
    Drive more, worry less
  1. Noise from rear 04 GT GP
    By GOGOPONTIAC in forum General Grand Prix Discussion
    Last Post: 09-23-2015, 11:27 PM
  2. Popping noise in rear?? HELP
    By 3R1CD4V15 in forum Brakes/Suspension/Chassis
    Last Post: 01-18-2012, 01:56 PM
  3. Rear end noise
    By reddog in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2011, 07:12 PM
  4. Humming noise from rear of car
    By jokyfo in forum Tires & Wheels
    Last Post: 06-04-2010, 01:36 PM
  5. Rear noise
    By musiknjoyr in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2010, 03:09 PM
