I'd start by removing and cleaning both battery cables and then make sure they go back on nice and tight. Then I'd check the grounds on the trans. Loose/corroded cables can cause all kinds of strange things to happen.
I'm hoping it is a easy fix such as a loose ground. Bronco, she was driving at the time of loss power, that being gauges, radio, etc.
Could a corroded ground cause the surging and loss of power? Or am I looking at two separate causes.
Thank you, once again.
