Thread: Electrical problems.. yay!
Results 1 to 20 of 20
  1. #1 Electrical problems.. yay!
    SE Level Member VicRDE82's Avatar
    Apr 2016
    Dickinson, TX
    So just got a text from my wife saying the car was surging under acceleration. I told her I would look into it when I get home and the next text was that the car lost all electrical power while driving. My question is there something that could tie the surging and the power loss together? Perhaps a bad ICM, or not likely but a bad ground to the body?
    I am more of a mechanical guy and not so much a electrical savy one. Any and all pointers are welcomed in advance.
    Btw the care is a 06 GT with 136k on her.
  2. #2 Re: Electrical problems.. yay!
    Jul 2010
    Coquitlam,BC,Canada
    Lost all power? No lights? Anything? Or won't crank? Cranks but won't start?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Electrical problems.. yay!
    St. Louis
    I'd start by removing and cleaning both battery cables and then make sure they go back on nice and tight. Then I'd check the grounds on the trans. Loose/corroded cables can cause all kinds of strange things to happen.
  4. #4 Re: Electrical problems.. yay!
    Apr 2016
    Dickinson, TX
    I'm hoping it is a easy fix such as a loose ground. Bronco, she was driving at the time of loss power, that being gauges, radio, etc.
    Could a corroded ground cause the surging and loss of power? Or am I looking at two separate causes.
    Thank you, once again.
  5. #5 Re: Electrical problems.. yay!
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by VicRDE82 View Post
    Based on that, I'm with the others about a bad ground or connection.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Electrical problems.. yay!
    GTP Level Member
    Jun 2016
    Cleveland ohio
    bad ground will cause all sorts of funky issues. check all grounds and battery terminals. make sure all of the relays and fuses are seated properly.
    BTW- Whatever my wife says happened I usually just go by "then it died". listening to a woman (besides Spazz) will probably lead you in the wrong direction on the car.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  7. #7 Re: Electrical problems.. yay!
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by rickisrad View Post
    ^ This! Applies to women AND people that think all cars look alike. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Electrical problems.. yay!
    Apr 2016
    Dickinson, TX
    Lol! I will check the basics and let you all know. Thanks for the advice.
  9. #9 Re: Electrical problems.. yay!
    May 2012
    Where winter never ends
    Unclear -- Did it die, as in no power what-so-ever, wont crank etc OR did it just loose the radio/gauges/accessories?
    2000 Regal - Winter Beater
  10. #10 Re: Electrical problems.. yay!
    Apr 2016
    Dickinson, TX
    Just the electronics. She was still able to drive, then everything just came back on while still driving.
  11. #11 Re: Electrical problems.. yay!
    Jul 2010
    Coquitlam,BC,Canada
    If its running, go around and wiggle all the wires and hopefully it will stop running.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Electrical problems.. yay!
    Apr 2016
    Dickinson, TX
    So a little update.. I drove the car and noticed the "chugging" my wife was talking about. It starts at about 35mph through 50mph when I'm barely giving it any gas. If I power through it, it goes away. So I decided to clean the MAF, TB, change the plug wires (plus were done earlier) and clean my grounding connections. Tops of the coil pack towers were clean, no cracks that I saw.
    Took it for a drive and it is still doing the same. It seems to do it after heavy traffic (maybe heat related?). Anything else I should check guys n gals?
  13. #13 Re: Electrical problems.. yay!
    Quincy, Mass
    What's your temp gauge saying. My wife's 06 had a clogged radiator and it want getting hot enough to over heat but hot enough to shut the AC compressor off till it cooled down.
    She also had a similar electrical issue and it would say charging system error on the DIC. Ended up having to replace both battery clamps and it fixed it.
    No more GP 04 Impala SS Indy:
  14. #14 Re: Electrical problems.. yay!
    Apr 2016
    Dickinson, TX
    Temp gauge is around 200, (got a bigger radiator and water pump within the last year). Did the charging system error cause a surge as I had described? I'm wanting to say it is fuel or spark related but not wanting to throw money at problems that aren't the cause.
    Thank you.
  15. #15 Re: Electrical problems.. yay!
    Apr 2016
    Dickinson, TX
    So driving the car and all the electronics shut off and came back on again.. first time it said "check fuel injection system", this time it said "service theft system". This car is more temperamental
    than my ex girlfriend!
  16. #16 Re: Electrical problems.. yay!
    Quincy, Mass
    Maybe you have a bad pcm.
  17. #17 Re: Electrical problems.. yay!
    Apr 2016
    Dickinson, TX
    Is there a way I can go about testing that??
  18. #18 Re: Electrical problems.. yay!
    Nov 2011
    NY
    Yeah, put a different one on and see if the problems are still there.
    sorry... Had to...
  19. #19 Re: Electrical problems.. yay!
    SE Level Member jimzssei's Avatar
    Sep 2014
    If you haven't yet, check the ignition switch.
  20. #20 Re: Electrical problems.. yay!
    Apr 2014
    CT
    i was thinking the ignition switch too, seems to be classic symptoms.
  1. Serious Electrical Problems!!
    By mares666 in forum Audio, Security & Visual Electronics
    Last Post: 06-02-2015, 06:16 PM
  2. help electrical problems
    By baddiesel in forum General Tech Discussion
    Last Post: 12-04-2012, 06:50 AM
  3. A/C Electrical Problems
    By ryanrice in forum General Tech Discussion
    Last Post: 05-24-2010, 10:43 PM
  4. Electrical Problems 98 GTP
    By KawaFord in forum General Tech Discussion
    Last Post: 07-31-2009, 08:20 AM
  5. Electrical problems
    By Baumku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:31 PM
