Thread: Fuel pump running with key off
Results 1 to 20 of 25
  1. #1 Fuel pump running with key off
    I break stuff selliott's Avatar
    Kansas City
    So this new issue started the other day when i came out to a dead battery so I hooked the charger up and the fuel pump kicked on with the key off, I turned the ignition on and off a couple times to see if it would kick off but it stayed on. I have the caspers hotwire kit I replaced the relay thinking it might be bad but that wasn't it. I presently have the fuse pulled on the hotwire kit to shut it off. Any suggestions? My dd is at the body shop so I'm forced to drive my b1tchy Gp so I need to get this issue figured out.
  2. Likes NotEnoughGPs liked this post
  3. #2 Re: Fuel pump running with key off
    GXP Level Member
    Mar 2015
    Tomball
    Well something is turning on the relay. Did it ever work correctly?
  4. #3 Re: Fuel pump running with key off
    GXP Level Member
    Mar 2015
    Tomball
    If the Casper has its own relay is it positive or negative triggered?
  5. #4 Re: Fuel pump running with key off
    Kansas City
    Yes it worked for years. And I have no idea sorry
  6. #5 Re: Fuel pump running with key off
    GXP Level Member
    Mar 2015
    Tomball
    I'm not familiar with the rewire as I have always done my own since the amps are already back there so there's power. Then I use the stock fuel pump wire to turn on the "Hotwire" rewire. If you replaced the relay I'm assuming you meant the one in the fuse box. If so you will need a meter to check terminals 85 and 86 for power. You should have +12v on one and the other should be switched common (-12V) that is the turn on and off for the relay. If you turn the key on it should prime and go off after 2-3 seconds. If you don't get it to turn off the wire from the PCM may be shorted to ground. Check the harness that runs from the fuse box to the PCM it can get cut from the belt if the loom is loose.
  7. #6 Re: Fuel pump running with key off
    Kansas City
    I replaced the relay on the hotwire kit. I think the kit bypasses the stock one, I pulled the stock relay and it didnt do anything the pump still ran I will break out the meter tomorrow
  8. #7 Re: Fuel pump running with key off
    GXP Level Member
    Mar 2015
    Tomball
    It still ran without the relay installed?
  9. #8 Re: Fuel pump running with key off
    Kansas City
    Yes with the factory one under the hood but not when I pulled the one on the kit
  10. #9 Re: Fuel pump running with key off
    GXP Level Member
    Mar 2015
    Tomball
    So what triggers the relay on the kit? Is it possible for you to draw up a little schematic as there are at least a dozen ways to skin this cat when it comes to how to power the pump.
    It would seem to me that you would use the factory fuel pump relay to turn on the kit relay. You could also just have it connected to an ignition hot (not recommended), you could even have it on a switch, in a ditch with a witch.... but I digress. There's a lot of ways to do it.
    Jeff
  11. #10 Re: Fuel pump running with key off
    Kansas City
    Could it be the neutral safety switch? I put it in neutral and the pump shut off?
  12. #11 Re: Fuel pump running with key off
    Kansas City
    http://intense-racing.com/Merchant2/docs/102152.pdf here is the link to the instructions maybe better than me drawing a schematic
  13. #12 Re: Fuel pump running with key off
    GXP Level Member
    Mar 2015
    Tomball
    It sounds like the Casper's relay is bad and is sticking in the closed position. As it says in the instructions the factory fuel pump relay turns on the Casper's relay. Why it shut off when you shifted into Neutral is beyond me, and seems like it would just be coincidence. Ask yourself this: If you removed the fuel pump relay that turns on the Casper's relay how could the relay stay on? The only logical answer is either the relay is stuck closed (which happens occasionally) or or there is something going on with the wiring. I know for a fact that the factory relay's coil gets +12V from the ignition and that the other side of the coil is driven from the PCM. The relay sends 12V to the fuel pump. When you use this rewire, you are using the 12V that would normally turn on the pump to turn on the relay in the rewire. so at this point it would seem to me to be a bad relay. There may be other factors involved, but you have not made me aware of them.
    Jeff
  14. #13 Re: Fuel pump running with key off
    Kansas City
    Jeff are you in Tomball TX? Yesterday i replaced both relays, I started with the factory one under the hood and when I pulled that one the pump should have shut off but did not. So you think its something in the wiring its self? I just took it out for a drive came back when I shut it off the pump stayed on when I put it back in neutral it shut off. I'm so confused. I'm sure it's a coincidence but that's twice.
  15. #14 Re: Fuel pump running with key off
    GXP Level Member
    Mar 2015
    Tomball
    Yup, but I work in Houston.
    It sure seems to be a wiring issue, though I am not sure why putting it in Neutral would have any effect on shutting it off, unless there is some kind of feedback that is just enough to activate the relay in the rear. It may be a chaffed wire or something. Like I said I have always run fuel pumps off of my amp wiring since it's already back there. On 4X4's I usually have a main power wire to run for fans and such so I typically use that as well, plus I'm running all the wires anyway. This system I am not familiar with, but basically you should have a heavy gauge wire with a fuse near the front, a trigger wire for the relay. (I usually use a negative, but they are using positive from what I can tell), and a wire leading to the pump. The way I run something like that is:
    87+86 B+
    30 to pump
    85 to switched ground.
    The other way to run it is:
    87 to B+
    30 to Pump
    85 to ground
    86 to switched positive (for turn on)
  16. #15 Re: Fuel pump running with key off
    Kansas City
    I live presently in porter and work in Conroe. Come fix this pos lol. Ok here comes the stupid question what is the 87,30,85,86 numbers?
  17. #16 Re: Fuel pump running with key off
    Numbers refer to what they do on the relay.
  18. #17 Re: Fuel pump running with key off
    Kansas City
    Thanks cam. I just went out to check grounds and the pump was running tried the neutral trick didnt work so just 2 coincidences I pulled the factory relay again to see but that didn't shut it off so I just pulled the fuse.
  19. #18 Re: Fuel pump running with key off
    GXP Level Member
    Mar 2015
    Tomball
    Bring it over and I'll fix it. May be easier to bring it to the shop... I have AC here. I grew up in Conroe, and Porter isn't that far from Conroe down 1314.
    Jeff
  20. #19 Re: Fuel pump running with key off
    Kansas City
    What does your schedule look like for the next few days? How much will you charge me for your trouble? Pm me your contact info.
  21. #20 Re: Fuel pump running with key off
    Apr 2016
    Maryland
    I really don't want to ask this question but I have to know. What's the point of doing this "hotwire" ?
  1. Running out of fuel pump?
    By BoostedPontiac in forum PCM Tuning
    Last Post: 12-04-2015, 08:49 PM
  2. 04/05 fuel pump install- Fuel pump access in trunk
    By chrsmi1 in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2015, 09:26 PM
  3. Replies: 7
    Last Post: 11-05-2014, 10:09 AM
  4. Trying to get the 90 Prix running... fuel pump questions
    By 90PrixSE in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-15-2012, 01:17 AM
  5. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
