Thread: Low speed noise, what is it?
Results 1 to 2 of 2
  1. #1 Low speed noise, what is it?
    AZ
    Looking for ideas on what this might be. Car is a 2001 GP w/ 3.8, non-SC, 120K miles, I've owned since 25K.
    When coming to a stop, say from 5 mph down to 0, it makes a sort of low growling noise, almost a vibration rather than a noise you can hear. Also sometimes makes the same noise starting up from 0 until 5 mph. Been doing this for maybe a year or more. I've recently replaced the front hubs (they had some play), which made no difference in the noise. At the same time as doing the hubs, I replaced the front pads (rotors looked fine) and the rear rotors and pads, also made no difference in the noise. So I figured must be the rear hubs, but when I take off a rear wheel/caliper/rotor and rotate the hub it is not rough at all, and has no play. So what the could it be? The axle half-shafts were replaced about 50K ago, they were Card One (chinese?), could they be bad and causing it? Any suggestions appreciated.
  2. #2 Re: Low speed noise, what is it?
    I would hook up the vehicle to a live data scanner than can read each wheel sensor.
    The 0-5mph first vibration noise should be the ABS self test they run but if it keeps happending when you come to a stop I'd guess one of the sensor is dropping out to zero and causing the ABS to function. It may not be this but I would do it to rule it out.
  1. Impala - grinding noise that goes along with speed
    By 02NavyBlue in forum General Grand Prix Discussion
    Last Post: 04-06-2015, 12:46 PM
  2. knocking noise louder with increased speed
    By mofford12 in forum General Grand Prix Discussion
    Last Post: 11-26-2012, 07:43 AM
  3. Low speed Wheel Bearing Noise? -97 GTP
    By 3R1CD4V15 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2012, 04:11 PM
  4. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  5. Loud noise at speed
    By ionroller in forum 04+ Specifics
    Last Post: 10-27-2009, 02:26 PM
