Thread: any idea how much my gp is worth?
Results 1 to 3 of 3
  1. #1 any idea how much my gp is worth?
    Sep 2015
    Lansing, Michigan
    02 gp gt. Just hit 200k. Tons of work done in last 4,000 miles.
    New:
    -Lower intake manifold gaskets-aluminum ones by fel pro
    -upper intake plenum along with upgraded egr pipe thing
    -fuel injector o rings, throttle body gasket, pcv valve, map sensor, fuel pressure regulator, crank sensor, valve cover gaskets with new grommets, front tires, battery, plugs, plug wires, fuel filter,
    -shift solenoids with transgo shift kit, fluid, filter change
    -new cheap jvc head unit with steering wheel control adapter
    -thermostat
    -straight piped the exhaust and kept stock diameter so it has a really nice deep rumble.
    Theres probably more. Body has some scratches and front bumper has a crack and some scrapes but no rust anywhere. The ac doesnt work and the stabilizer bar broke near the end link. I cant think of anything wrong with it mechanically
    Was wanting to trade it for an 04 gp gt. It has 174k and guys asking 2650.
  2. #2 Re: any idea how much my gp is worth?
    $1,500-3,000, depends on the buyer.
  3. #3 Re: any idea how much my gp is worth?
    your around 2000 ish, check nada and kbb.
    whats wrong with the 04 that is its 2650? you might be doing all the same work all over again.
  1. manual fan switch: good idea bad idea?
    By asite57 in forum General Tech Discussion
    Last Post: 04-22-2012, 01:15 PM
  2. Is it worth it to put more money into the car than what its worth?
    By xander37 in forum General Tech Discussion
    Last Post: 01-17-2012, 06:28 AM
  3. Good Idea or Bad Idea?
    By Robby Avery in forum Turbo
    Last Post: 01-25-2011, 04:55 PM
  4. Good idea - Bad idea?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 04:51 PM
