Thread: Instrument cluster acting funny
Results 1 to 9 of 9
  1. #1 Instrument cluster acting funny
    Aug 2016
    Lehigh Valley PA
    This morning on my way to work the fuel guage, tach, t/c, temp and odometer stopped working. When I put it in park the doors didn't unlock. Here's a pic of the dash.
    I shut the car down and fired it back up and all is ok for now. I'll see what happens on my way home. Any ideas or do you think it was a one time occurance?
  2. #2 Re: Instrument cluster acting funny
    Hard to say, I'd want to guess at the ignition switch but that is just a guess.
    They do cause very crazy electrical problems sometimes.
  3. #3 Re: Instrument cluster acting funny
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    How long have you had the stereo?
    Some people have issues after installing an aftermarket stereo..
  4. #4 Re: Instrument cluster acting funny
    Aug 2016
    Lehigh Valley PA
    I put the radio in a couple weeks ago. The only things that don't work since doing that is the door chime and date on the DIC. Those are both known issues I'm ok with not having.
  5. #5 Re: Instrument cluster acting funny
    GXP Level Member
    Mar 2015
    Tomball
    What module did you use. It's pretty common as I've followed at least 15 different people that had the same or similar issues. Usually has U1000 codes when you pull them.
  6. #6 Re: Instrument cluster acting funny
    Aug 2016
    Lehigh Valley PA
    I have the RP5-GM11 steering wheel control module. I had a similar instance with my '08 Silverado. Gauges went crazy, shut the truck off and restarted without any issues since. A GM tech told me it could be a bad ground somewhere. Dunno, as long as it doesn't happen again. Thanks for the replies.
    What is the U1000 code? Will it show on a regular OBII scanner?
  7. #7 Re: Instrument cluster acting funny
    OKC, Oklahoma
    Quote Originally Posted by J57ltr View Post
    Jeff?
    Quote Originally Posted by GYSOT View Post
    You can clean your battery terminals and make sure they stay clean, but is more of a system related issues rather than just dirty ground unfortunately for whoever decided to switch to an aftermarket head unit.
    The code is for lost communication and there will be another code with it too to identify the lost communication source, some cars are equipped with CAN bus, I believe GM started to use this in just about every vehicle in 2008 reason why you experienced issues with the Silverado.
  8. #8 Re: Instrument cluster acting funny
    GXP Level Member
    Mar 2015
    Tomball
    U1000 series codes are loss of communication codes. There's a bunch of them, and if you go through the audio section you will see some of the common ones mentioned.
  9. #9 Re: Instrument cluster acting funny
    Aug 2016
    Lehigh Valley PA
    Thanks again for the replies
  1. Trans acting funny
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-04-2013, 10:10 PM
  2. HVAC acting funny
    By Fahrenheit in forum General Grand Prix Discussion
    Last Post: 03-11-2012, 01:16 AM
  3. Transmission acting funny
    By kcirrab in forum General Tech Discussion
    Last Post: 04-09-2011, 10:11 PM
  4. 3.8 N/A acting funny
    By Pontiac Cali Guy in forum General Tech Discussion
    Last Post: 04-07-2011, 11:00 AM
  5. Grand Prix acting funny at stoplights and weird accel help
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 06-27-2009, 08:24 AM
