Quote Originally Posted by J57ltr View Post
What module did you use. It's pretty common as I've followed at least 15 different people that had the same or similar issues. Usually has U1000 codes when you pull them.
Jeff?
Quote Originally Posted by GYSOT View Post
I have the RP5-GM11 steering wheel control module. I had a similar instance with my '08 Silverado. Gauges went crazy, shut the truck off and restarted without any issues since. A GM tech told me it could be a bad ground somewhere. Dunno, as long as it doesn't happen again. Thanks for the replies.
What is the U1000 code? Will it show on a regular OBII scanner?
You can clean your battery terminals and make sure they stay clean, but is more of a system related issues rather than just dirty ground unfortunately for whoever decided to switch to an aftermarket head unit.
The code is for lost communication and there will be another code with it too to identify the lost communication source, some cars are equipped with CAN bus, I believe GM started to use this in just about every vehicle in 2008 reason why you experienced issues with the Silverado.
