Thread: 2000 GT leaking tranny fluid
Results 1 to 3 of 3
  1. #1 2000 GT leaking tranny fluid
    SE Level Member Lawenforcer's Avatar
    Shelbyville, IL
    Hello, I am starting this new project. First thing I want to do is fix the tranny fluid leak. It appears it is coming from where it goes in the radiator. So I'm guessing a new fitting should fix it. Is there a trick to getting to the fitting the easiest way? Anything I should know about it? If I go thru the bottom I have the "plastic protector", sorry can't think of proper name, under the car and I unscrewed it and it doesn't want to come out and hate to bust it...any help would be appreciated...Thanks
    2000 Grand Prix GTP
  2. #2 Re: 2000 GT leaking tranny fluid
    Shelbyville, IL
    It's leaking somewhere under the radiator hose...so guessing it's the lower tranny fitting...is there anything else down there that could be leaking the tranny fluid?
  3. #3 Re: 2000 GT leaking tranny fluid
    St. Louis
    The only thing there is the line. The lower air dam should pull out once you get all the screws and any push pins removed.
  1. Transmission leaking fluid from the top?
    By awildryan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2014, 06:37 PM
  2. Leaking oil or trans fluid?
    By zildjian102 in forum General Tech Discussion
    Last Post: 10-30-2010, 02:17 PM
  3. 98 GTP leaking tranny fluid
    By millfire517 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2009, 11:02 AM
  4. Leaking tranny fluid
    By c002529 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2009, 07:00 AM
  5. Help!! Tranny leaking fluid
    By NMillis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 06:48 AM
