Thread: torco accelerator
Results 1 to 9 of 9
  1. #1 torco accelerator
    Kemmerer, Wyoming
    I order a case (6 32 ounce bottles) of Torco Accelerator. It raises the octane in increments of 5, so if you add 8 ounces to 5 gallons of gasoline then the resulting octane is 96, 16 ounces added to 5 gallons makes 101 octane, and 32 ounces added to 5 gallons makes 105 octane. I think 105 octane is the limit because if the blending guide was linear then it would only take 24 ounces to make 105, and 32 ounces would make 110 octane.
    Several weeks ago I ran my car with a 3.0" pulley and 15* of timing. I maxed out at 6.2* of KR. I'm going to the track next weekend, and I don't want to over-mix, so I can use it for a long time.
    The question is: does raising the octane by one point deduct one degree of kr?
    I have enough concentrate to mix 60 gallons of 101 octane, but if 96 octane will get the job done, then I have enough to treat 120 gallons, and it wouldn't be hard for me to justify adding it to every tank of gas.
    http://www.torcoracefuel.net/
  2. #2 Re: torco accelerator
    SWPA
    When it says increments of 5, it is usually .5 octane.
  3. #3 Re: torco accelerator
    Kemmerer, Wyoming
    I think that is true with the cheap "octane booster" I have more faith in this stuff.
  4. #4 Re: torco accelerator
    Torco is real octane booster, not that cheap crap you buy at the parts store. This stuff really does raise octane rating by the amount given.
    Octane rating and knock do not go hand and hand like that. Getting 5º of knock on 91 doesn't mean you'd see 3º with 93 octane.
    Do some math and run around 98-100 octane and see what happens. I think you'll have to up your pulley size in the end because 6º of knock on a 3.0 pulley is alot. It's more dangerous than 6º on a 3.4 because of the added boost pressure.
  5. #5 Re: torco accelerator
    Kemmerer, Wyoming
    I have the 3.2" pulley on now, and driving around town with some highway pulls, I don't see more than 1* of kr with 15* of timing. The next track day is Saturday the 13th, and I think I have enough gas in my tank to make it there, while being almost empty of the 91 octane. looking at the conversion chart, 101 octane is the happy medium, as getting 105 octane takes double the amount to make the 101 blend.
    for some reason, when i'm at the track, I don't see near as much kr. last time I went I had like 2 blips of 1* of kr. that was with the 3.2" pulley and I think my max timing ended up being 19*. and I was running 96 octane then. this is the reason I want to try the 3.0" pulley.
  6. #6 Re: torco accelerator
    Quincy, Mass
    Go to a 3.3 and add some timing and you might like it better
    No more GP 04 Impala SS Indy:
  7. #7 Re: torco accelerator
    Kemmerer, Wyoming
    I don't have a 3.3
  8. #8 Re: torco accelerator
    Quincy, Mass
    Well stop driving so fast, save some gas mileage and use that money to get a 3.3...
  9. #9 Re: torco accelerator
    Kemmerer, Wyoming
    Any idea if torco will raise the octane of 100 octane ll avgas
  1. surging as if pumping accelerator
    By blazineagle in forum Engine
    Last Post: 01-02-2012, 01:44 PM
  2. accelerator seizing up
    By gearhead1001 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2011, 11:00 PM
  3. Dual brake/accelerator
    By juicestain100 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2010, 11:15 AM
  4. car cranks but wont start unless you press accelerator
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 10:49 PM
  5. Accelerator cable slack?
    By dagger in forum General Tech Discussion
    Last Post: 04-07-2009, 09:09 PM
