Thread: Starter Removal question?? It is stuck on
Results 1 to 16 of 16
  1. #1 Starter Removal question?? It is stuck on
    canal winchester, ohio
    On a non-Pontiac car I went to change the Starter. I have all bolts out. I have it unhooked. It is stuck on. I have been pounding on it. It wont come off. Can I re-hook the battery cables and bump the starter to see if that will help loosen it? Any suggestions? And YES, I have all the bolts off, there is nothing holding it 2010 Kia.
    Any tips are appreciated!
  2. #2 Re: Starter Removal question?? It is stuck on
    i guess you can try to have some one bump it while you hold it and pull it off.
    is there no wiggle to i tat all? i got no clue what a kia starter set up is, so im really blind on this one.
  3. #3 Re: Starter Removal question?? It is stuck on
    Just worried I could somehow cause damage to it by bumping it.....cant see how but thought I would ask
  4. #4 Re: Starter Removal question?? It is stuck on
    GTP Level Member buickman104's Avatar
    NYC
    Car seems too new to have a starter rusted into place. Since it is not that old sometimes the simplest solution is the answer. Are you 100% you did not miss any hidden bolts?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: Starter Removal question?? It is stuck on
    Apr 2016
    Maryland
    I had this problem with my gxp. The dowels were holding it in place. Wasn't rusted just really stuck on there. I sprayed it with pb blaster and just pryed it at every angle I could get to and it eventually came off. One of the dowels even stayed on the car and I had to use vice grips to work it out. Good luck
  6. #6 Re: Starter Removal question?? It is stuck on
    St. Louis
    Heck, if the starter is junk already just smack it with a rubber mallet a few different directions and see if it comes loose.
    And a 2010 Kia what?? Might help if we knew the model and engine size. There may be a trick to it.
  7. #7 Re: Starter Removal question?? It is stuck on
    You are missing something.
    Scott needs to move this out of w body....
    There's at least one more bolt holding you up. Search on teh starter and get a picture. You likely will see where it's held up.
  8. #8 Re: Starter Removal question?? It is stuck on
    Not missing a bolt, 100% sure of that. Thanks anyways!
  9. #9 Re: Starter Removal question?? It is stuck on
    SE Level Member Cruisin38's Avatar
    Sep 2015
    Northern Illinois
    4 of my friends are techs at a nearby kia dealer.
    Which kia and which engine do you have? I can ask em if there's more to it
  10. #10 Re: Starter Removal question?? It is stuck on
    Seriously? That's great. 2010 Kia Sedona. Seemed like straight forward job until I couldn't get it off. I put the bolts back in and punted and I am going to try another day (starter is intermittent)
  11. #11 Re: Starter Removal question?? It is stuck on
    Sep 2015
    Northern Illinois
    They're telling me it's just the two bolts holding it up and it should come right out, they never had a stuck starter on any kia.
    Is there a spot you can get a pry bar in to maybe pop it away from the block?
  12. #12 Re: Starter Removal question?? It is stuck on
    Thanks man!!!
  13. #13 Re: Starter Removal question?? It is stuck on
    I did the starter today. Starter came right off. Strange. Glad.it came off. Thanks for the help.
  14. #14 Re: Starter Removal question?? It is stuck on
    Magic.. gotta love it when something fights one day and you take the pass...then it works like a champ. Congrats!
  15. #15 Re: Starter Removal question?? It is stuck on
    Apr 2016
    Maryland
    That's crazy
  16. #16 Re: Starter Removal question?? It is stuck on
    SWPA
    I've had my fair share of that. One time in particular I was putting the trans back in my Stealth by myself. It was fighting my going back on the input shaft. I would get it on the shaft, but it refused to clock into place. I fought it for close to an hour and my back was starting to kill me. I threw it back on the floor and went in the house for a breather, went back out, grabbed the trans, and the fvcker slid right into place.
  1. quick question ( starter) need asap!
    By titanfan12 in forum General Grand Prix Discussion
    Last Post: 02-16-2014, 08:16 PM
  2. L26 oil pan removal, stuck on, help
    By machinegunsquid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2011, 03:34 PM
  3. Starter Question
    By skunktriscuit in forum General Tech Discussion
    Last Post: 08-01-2011, 07:31 PM
  4. Valet 552t remote starter question
    By shawnz90 in forum Audio, Security & Visual Electronics
    Last Post: 10-27-2009, 09:40 AM
  5. Starter removal
    By airhead in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-04-2009, 01:03 PM
