Thread: Driver side AC 15º warmer than Pass side
Results 1 to 11 of 11
  1. #1 Driver side AC 15º warmer than Pass side
    GT Level Member Exile's Avatar
    Chicago
    The driver side of my 2001 GP w/ dual zone climate control is about 15º warmer than the passenger side...which isn't desirable since I daily this to work by myself!
    Any idea what the cause may be and solution? It has been like this for a couple summers now.
    2001 Black GTP Special Edition
    KYB Excel-G struts, Dorman & GMPP swaybars, Dorman/WBS trailing arms, K&N CAI, ZZP 3" DP, Thrush GP, all new calipers
    And the GP appropriate gas cap fender rust
  2. #2 Re: Driver side AC 15º warmer than Pass side
    A blender door problem maybe.
  3. #3 Re: Driver side AC 15º warmer than Pass side
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I'm interested in an answer too.. My passenger side is slightly cooler than the drivers side. Been like this ever since I've owned the car for 6-7 years now. I almost wonder if it's low on R134? Never hooked a gauge up to it though.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  4. #4 Re: Driver side AC 15º warmer than Pass side
    GTP Level Member
    Oct 2014
    If it's not a blend door. AC might just enter the car on the passenger side and as it travels accords the dash in the ducts it warms and will never be as warm.
    Maybe point a couple passenger vents towards the driver side.
  5. #5 Re: Driver side AC 15º warmer than Pass side
    Jan 2014
    AR
    When mine gets that way, I know its low on refrigerant. Been driving them 7 years now and its always that. Only with a full charge will the driver's side be as cold as the passenger's. Must be how airflow through the core is set up.
  6. #6 Re: Driver side AC 15º warmer than Pass side
    Chicago
    Quote Originally Posted by idrivejunk View Post
    I just put two 12oz cans of charge in. The system was completely empty due to a slow leak somewhere. Hoping the dye leads me to that.
    Today it had to of been a 20-25 degree difference. I read on a thread somewhere GP's can hold 36oz of freon? Probably best to get a gauge before I try another...
  7. #7 Re: Driver side AC 15º warmer than Pass side
    The A/C sticker should be on one of the strut towers if I remember right. They hold about 1.88lbs of R134a.
  8. #8 Re: Driver side AC 15º warmer than Pass side
    Nov 2015
    WI
    Mine also did this and it was low on Freon i added 24 oz and now both sides are ice cold. My gauge was at 25 psi before adding the 24 oz.
  9. #9 Re: Driver side AC 15º warmer than Pass side
    GT Level Member mguzzo's Avatar
    Buffalo NY
    1997-1998 is 1.8 lbs
    1999+ is 2.2 lbs
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  10. #10 Re: Driver side AC 15º warmer than Pass side
    Jul 2016
    Indianapolis
    I joined this forum specifically to try to fix a very similar problem with my sons 2001 Gran Prix GTP. I had pulled the driver side actuator to make sure the door had full travel & it did. I was scratching my head as the compressor seems to run for the normal amount of time & did not short cycle due to low refrigerant but I'll hook the gauges up to it to see if it is a bit low. Thanks for a quick (possible) answer!
  11. #11 Re: Driver side AC 15º warmer than Pass side
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    I came across a TSB from GM a couple months ago when I replaced my compressor. It basically said that some GM vehicles were not charged with the correct amount of refrigerant from the factory which caused insufficient cooling. The updated amount that was called for was 2-1/4 lbs. Also calls for an updated sticker to reflect the correct capacity. The TSB # is 99-01-38-005 if anyone is interested in reading it.
    I'm not sure if that's the fix for you OP, but it's good info for future reference.
  1. Replies: 1
    Last Post: 10-02-2013, 07:52 PM
  2. Replies: 2
    Last Post: 02-14-2012, 08:47 PM
  3. Driver side wiper arm slips down to the side mirror
    By kappian in forum General Tech Discussion
    Last Post: 04-05-2010, 08:43 PM
  4. Side mirror on driver's side
    By jokyfo in forum Shops and Community Heroes
    Last Post: 04-29-2009, 03:50 PM
