Thread: Trouble turning over
Results 1 to 6 of 6
  1. #1 Trouble turning over
    Nov 2008
    sc
    I have an '04 GT, probably ever other time i start it the rpm gauge goes up like it normally does but then it just goes back to zero and it doesnt start, so I end up having to give it gas to turn over. Once the car starts its fine. Is that just a spark plug problem? I dont know cars very well so Im jsut searching for advice.
    -thanks!
  2. #2 Re: Trouble turning over
    Hoffman/Schaumburg, IL
    It is more likely a fuel issue, when you press down the gas and start the car, the computer actually pulls fuel from the engine's normal amnt......
    Do you have a Check engine light? Id so, have the codes read
    Is this always, or a one-time deal?
    Was it extremely hot/cold?
  3. #3 Re: Trouble turning over
    Nov 2008
    sc
    nope no service lights, its runs perfect. aside from the turning over problem once in awhile, sometimes on start up it idles a few hundred rpms higher than normal but it goes away after I put it in drive. ( 87k miles btw)
  4. #4 Re: Trouble turning over
    Nov 2008
    conn
    hows the fuel filter ?
  5. #5 Re: Trouble turning over
    Dryden
    Did you ever find out what the real issue was. My car is acting the same way.
  6. #6 Re: Trouble turning over
    Check for fuel pressure to before start up. If you don't have enough it can't start.
  1. headlights not turning on
    By nemesis in forum General Tech Discussion
    Last Post: 05-16-2016, 06:37 PM
  2. My 08 is turning out to be a LEMON
    By willie769 in forum The Rant Forum
    Last Post: 01-07-2009, 07:54 AM
  3. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
  4. popping sound when turning...?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2008, 07:49 AM
  5. 1st! Vibration while turning '93 Lumina
    By Abrasive in forum Chevrolet Lumina
    Last Post: 01-06-2008, 08:36 PM
