If you have a 12v lighted probe tester, you can test for a short to ground by connecting the probe to the positive terminal, and carefully probing the suspect wire at a connector end, so as to keep from damaging insulation. If it lights, then that wire is grounded somewhere. Be careful, however, since some sensors will not like being tested that way... I know somebody else on here knows what all is safe to test in that way...
