This is how I wedged a walbro 485 into a stock canister.
All parts needed.
Part numbers and prices.
Stock canister
White connector, stock.. prone to melting vs a pump like the 485 that draws a lot of current.
Start unplugging stuff... Since we're upgrading the connectors pop the fuel level sender pins out with the provided safety pin.
Have fun removing this from the stock pump. Save it, you will need it later.
After everything is unplugged, popping the connector out is EZ.
Baller connector pops right in no fuss.
This is all trash now... including venturi hose, toss it all.
Put the fuel level sender pins into the new in tank wiring harness (part number ITWH-029)
Make sure to slightly bend the little pins on the back that holds it in place.
EZ
New filter sock... you'll need a 15mm drill bit later.
See that prong?
Kill it.
Same with this...
Use your 15mm drill bit to put a carefully placed hole in the bottom of the canister.
Fit filter sock through the hole.
Have fun connecting the corrugated hose to the canister top and pump outlet.
Cap the stock return, break the little tabs on the evap port and drill it out with a 3/16th bit. This will be your new return line. It'll pour fuel in from the top, keeping the pump cool.
Gut the evap **** out of the top.
This is what you should have so far.
Now just plug the wiring harness in to the pump and top.
Replace all the little holding tabs for the connectors.
The new hotwire kit will adapt your stock wiring to the new connector that won't melt.
Now install the hotwire kit and plug it in.
The pump feeds right off the bottom of the tank, so you can make it home on ~1 gallon of gas if you need to.
It also retains fuel in the bucket keeping the pump cool.
The upgraded wiring and harnesses enture proper current to the pump without melting things.
This pump should support 250-300whp more than a walbro 255.
With the pump picking off the bottom of the tank, you can never suck the canister dry.
For guys maxing their 255s... this is a perfect solution.
