2005 Pontiac Grand Prix base model. No sunroof.
Water leaks from the map light into the front cup holder. I saw a few thread that this is probably the Onstar Antenna since I don't have sun roof (I will test it later to confirm). From what I read in this forum, it seems loosen the antenna bolt, and put some silicone between the roof and rubber seal outside should work. But how do I loosen the bolt of the antenna? I took out the map light and can see the antenna bolt. But it is so hard to get a wrench there. Do I need to take down the headliner as well? Or will a smaller flexible head ratchet work here? Any advice is appreciated.
