Thread: water leaks from the map light
Results 1 to 9 of 9
  1. #1 Re: water leaks from the map light
    Oct 2012
    USA
    Quote Originally Posted by spazzz View Post
    Don't remove the headliner....Eric what are you thinking.
    Get a Harbor Freight crows foot socket set. Not sure of the size but undoubtedly metric
    I can't remember what I used....vice grips? 8" pliers?
    FVck the on-star and clip the wire and stick a socket on it.
    Thanks for pointing out the tool. I thought it is possible to do it without taking out the headliner but my ratchet is too big for the small space. It is obviously easy if headliner is off but I want to avoid the hassle of taking it out.
    Am I correct that I only need to loosen the bolt? No need to take the antenna completely off the car, right?
    Do you know how GM seal it out of factory? Is it just a rubber seal that is pulled tight against the roof by the bolt?
  2. #2 Re: water leaks from the map light
    Nov 2012
    Madison
    Quote Originally Posted by Coldwaves View Post
    Yes to all your questions.
    It was 9 years ago when I did mine, it was easy and i didnt take the beadliner out.
    I just cant remember what specific wrench i used
  3. #3 Re: water leaks from the map light
    Oct 2012
    USA
    Thank you so much! I will probably try to fix it this weekend.
  1. Water leak under the cowl and srs light on
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 02-05-2013, 07:39 PM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. Valve Cover Gasket Leaks & Possible Intake Leaks
    By mechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2011, 07:48 AM
  4. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  5. 04 GP leaks water thru map lights.
    By schreurs1 in forum General Tech Discussion
    Last Post: 05-22-2009, 12:07 AM
