Thread: Power Lock Issue
Results 1 to 7 of 7
  1. #1 Power Lock Issue
    SE Level Member blackthunder's Avatar
    Jun 2013
    London, Ontario
    So funny thing has been happening....
    First my Drivers door lock wouldn't work with the key FOB. Now my passenger side is doing the same thing. The back locks work perfectly! Did i mention that sometimes the drivers side will work, sometimes it doesn't. But since the warmer weather has come, it barely works at all!
    I am hoping that this is a common issue and someone might chime in with a "So here's what you do...." kinda post.
  2. #2 Re: Power Lock Issue
    they work normal with the door switch?
  3. #3 Re: Power Lock Issue
    Jun 2013
    London, Ontario
    Same symptoms. fronts dont work, back does.
  4. #4 Re: Power Lock Issue
    could be the lock actuators both took a crap.
  5. #5 Re: Power Lock Issue
    Jun 2013
    London, Ontario
    will ones from an '01 work in my '04?
  6. #6 Re: Power Lock Issue
    not likely. look both parts up on line at a parts store, see if the part # is the same.
  7. #7 Re: Power Lock Issue
    GXP Level Member
    Mar 2015
    Tomball
    That's Odd I have seen several people with 04+ cars that describe the same or similar symptoms. My 05 will sometimes lock all the doors and other times it won't (meaning they move but not far enough to lock or unlock. Doesn't matter if it's the remote or the switch. They seem weak for some reason. It's like whatever relay is all carboned up so it makes intermittent contact. I replaced a couple of the actuators and it didn't seem to make a difference.
    Jeff
  1. Door lock issue
    By jlwonsit in forum How To Write-Ups/Tech Tips
    Last Post: 10-29-2018, 04:09 PM
  2. Door Lock Issue
    By kkobberstad in forum General Tech Discussion
    Last Post: 05-20-2014, 03:40 PM
  3. 05 GP anti-lock brake issue
    By mntnbiker in forum Brakes/Suspension/Chassis
    Last Post: 06-05-2013, 02:11 PM
  4. Driver's door power lock issue.. :(
    By daiadvisor2 in forum General Tech Discussion
    Last Post: 09-05-2010, 08:13 PM
  5. Door lock issue
    By GINOSGTP in forum Off Topic Discussion
    Last Post: 09-06-2009, 12:27 AM
