Thread: Brakes stuck, not sure what to check first.
Results 1 to 6 of 6
  1. #1 Brakes stuck, not sure what to check first.
    May 2016
    Dayton, Ohio
    Hey guys wondering if anyone had some input.
    Have a grand prix gtp with 90k miles on her.
    Recently got new caliper on drivers side, rotors brakes and wheel bearings on both sides.
    When I put the car in drive it doesn't move when I don't press gas, and when I do press gas slowly it lurches forward just a little bit. It almost feels like my parking brake but I'm not sure, just curious if anyone has experience with something like this and knows what to check. Going to take off wheels and inspect the brakes this weekend.
  2. #2 Re: Brakes stuck, not sure what to check first.
    Figure out what wheel is stuck and go from there.
    New caliper could be binding or another wheel is sticking.
  3. #3 Re: Brakes stuck, not sure what to check first.
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Just jack the car up and spin each wheel. It should spin by hand. If it doesn't, you found your problem wheel.
  4. #4 Brakes stuck, not sure what to check first.
    SE Level Member 01grandpri's Avatar
    Oct 2015
    allendale michigan
    Prolly the e brake .. One of the back tires I had it happen twice to me now
  5. #5 Re: Brakes stuck, not sure what to check first.
    May 2016
    Dayton, Ohio
    Anything specific you did to solve that after you figured out what wheel it was?
  6. #6 Re: Brakes stuck, not sure what to check first.
    Oct 2015
    allendale michigan
    Me personally..I don't use my ebrake. I took off the ebrake assembly and solved my problems
  1. key stuck and shifter button stuck 50% of the time
    By brugg125er in forum General Tech Discussion
    Last Post: 03-21-2014, 10:21 AM
  2. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  3. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  4. RPMs stuck at 4000 with check engine light
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2008, 12:25 AM
