So,
I'm pretty lost on this issue and I need some ideas. After my rebuild (and fixing all the stupid mistakes I made), my car would crank, fire up and run for somewhere around 3 seconds. When I would rev it to about 3 or 4k, it would run no problem. If I used HP Tuners to manually kick the fuel pump into "high", it would stay running for as long as I wanted, but it would backfire quite a bit.
Sounds like the fuel pump resistor right? I don't think so though. I used a racetronix fuel pump hotwire kit, with the walbro pump. After seeing the above symptoms, I bent pin 85 out on the fuel pump speed control relay. No change. I checked the ground for the hotwire kit and that's all good too.
After trying different things for a while, then starting it, it would stall; for a few times. Then it started flooding, to where if i pulled the fuel pump relay it would run by itself for 3 seconds and die.
However, now, it won't fire at all. It'll crank and crank and crank, but it won't fire. I still have 50 psi at the fuel rail, and I've got spark on every terminal from the coil packs. Plug wires have been triple checked, etc. The PCM is registering air going into the cylinders too.
What am I missing?
Mod list:
VS Cam
N* Throttle Body
FS intercooler
Pace Setter Headers (no cat, and the catback hasn't been put together yet)
AEM Wideband (not hooked into HP Tuners yet)
Yella Terra 1.6 rockers
Custom head work done by a reputable performance shop (stock size valves though)
42.5# injectors
Walbro fuel pump
Racetronix fuel pump hotwire
180 degreee tstat
AL104 plugs
EGR removed
PCM had a base tune for all the above mods done by Reptile, planned on tweaking/getting it tweaked once the car was actually running.
Also, I have a scan from the PCM if you need it.
Any and all help is appreciated.
