Thread: Engine flooding
Results 1 to 8 of 8
  1. #1 Engine flooding
    Dec 2013
    salisbury md
    04 3800sc engine floods on 1st start of day. Starts and runs great rest of the day no flooding. Ambient temp. Hot or cold makes no difference. ??
  2. #2 Re: Engine flooding
    Describe the "flooding".
    If it just starts and kills right away after like 2 seconds, it's not flodding the motor. It just can't get enough air inside to keep running.
    If you've never removed the throttle body and cleaned it, start there. They get so full of **** from the EGR that it blocks air flow and stalls out.
  3. #3 Re: Engine flooding
    Dec 2013
    salisbury md
    1st start must crank about 25 times, plugs are soaked with gas. Have replaced throttle body and TPS no help. Seems to be 1st start in closed loop 2nd start no problem ??
  4. #4 Re: Engine flooding
    Because of coolant temp settings in the computer and built in delays, they always start in open loop. Even when warm they have up to a 10 second delay before switching back to closed loop functions.
    Without me standing in front of this vehicle with a scanner of sort I am not sure what is causing this problem.
  5. #5 Re: Engine flooding
    SE Level Member b4black's Avatar
    Oswego, IL
    You might have a fuel pressure issue. Get a fuel pressure gauge and install it so you can see it from the driver's seat. See if the fuel pressure rises before starting and holds when you shut it off.
    Or try cycling the key on-off several times to build pressure before the first start of the day.
    2002 Buick Regal GS - Intercooler, TOG headers w/ full 3" exhaust, 60# injectors, K&N cone, MPS 2.9, GMPP sway bars and STBs, 18"GXP wheels, 12" impala rotors, alternator hotwire, fuel pump hotwire, HPTuner newbie, Flex Fuel And 1982 Buick Regal GN & 1996 Dodge Ram Diesel 4x4 & Richard Petty's 43 JR Hemi Barracuda drag car
  6. #6 Re: Engine flooding
    Dec 2013
    salisbury md
    Fuel pressure starts and holds at about 58 psi. Obd is not sending any trouble codes. Does anyone know what controls fuel flow on cold start ?
  7. #7 Re: Engine flooding
    did you clean the tb yet? thats step one.
    after it dont start, when it cranks a crap load of times, pull a spark plug, see if its wet. if its wet your getting gas.
    keep in mind, every time you turn the key off and back to run the injectors prime the engine. then they dont start to spray fuel until the engine fires up.
  8. #8 Re: Engine flooding
    He already replaced it, read the 3rd post.
  1. 91 caprice flooding out after running 5 min
    By dsmuts in forum General Tech Discussion
    Last Post: 03-25-2014, 01:44 AM
  2. 98 gtp gt flooding
    By IN2DeeP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2012, 10:31 AM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. Engine Flooding.
    By iroc34 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-05-2011, 01:49 AM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
