Thread: A/C Repair Question
Results 1 to 6 of 6
  1. #1 A/C Repair Question
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    Anybody know the PAG oil capacity of a 1997 GTP? I'm going to be replacing the compressor, orifice tube, accumulator, seals, schraders, etc. I would like to get this done correctly the first time so I wanna make sure I have all the necessary info. Install tips are appreciated as well.
    Edit: I should have googled first. Does 8oz sound about right?
  2. #2 Re: A/C Repair Question
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I think there's a sticker somewhere that will tell you that info. Couldn't hurt to look in the owners manual too.
  3. #3 Re: A/C Repair Question
    Apr 2009
    Upper Darby, PA
    The only sticker I found gives the part number for the oil, not the capacity.
  4. #4 Re: A/C Repair Question
    Apr 2015
  5. #5 Re: A/C Repair Question
    Apr 2009
    Upper Darby, PA
    I got the compressor and accumulator off today. No oil in either, so I'm assuming the whole system is dry.
    Should I just add the whole 8 oz? Half in the compressor and half in the accumulator then install them?
  6. #6 Re: A/C Repair Question
    Apr 2009
    Upper Darby, PA
    I'm at my breaking point with this pos ac system. I got everything installed fine, pulled vacuum overnight, made sure it held vacuum. All was fine until I went to add refrigerant. I hooked up my first can of 134a, bled the air from the service hose, and cracked the low side of the manifold gauge to begin sending in refrigerant. It shot up to 90 psi which seemed pretty high but I started the car anyway. The compressor clutch will not engage no matter what. I pulled the relay (#13) in the fuse box and jumped between pins 3 and 5 figuring that would jumpstart the clutch. Didn't work. Some guys in the chat mentioned the low pressure switch may be the issue, but I can only find one pressure switch on the high side line with 3 wires. I don't know which to jump between or if it's even safe to do so.
    One thing I'm thinking it may be as I sit here typing is the plug that goes onto the compressor. Does the orientation of that plug matter or will it work either way?
    I'm at a loss as to what it could be at this point.
  1. Diy ac repair question
    By pshabou in forum General Tech Discussion
    Last Post: 06-06-2015, 10:45 AM
  2. 1998 GTP supercharger repair kits repair cost
    By SpecialK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2015, 10:49 AM
  3. bumper repair question
    By 01gtp1506 in forum General Grand Prix Discussion
    Last Post: 07-16-2013, 11:24 PM
  4. Dent repair question.Is this possible?
    By MyteeMyk in forum Visual/Body Modifications
    Last Post: 06-12-2012, 06:47 PM
  5. Question about EBCM repair.
    By sk8erdude in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2012, 03:02 PM
