Thread: Coolant leaking out around bypass on LIM?
Results 1 to 6 of 6
  1. #1 Coolant leaking out around bypass on LIM?
    Sep 2015
    IL
    Changed my LIM gaskets and various other things about 3 months ago. All went well, continuously checked for leaks over the following weeks/months didn't find anything. But now I'm seeing coolant bubbling up and leaking around that coolant bypass (not sure that's what its called) on the LIM, right underneath the throttle body with the exhaust right in the way. Its a horizontal plate with two bolts. Out of all places this is where I find a leak? Only thing I can think of is I didn't snug the bolts up enough. Does anyone know the torque spec for it? Also is it easy to remove the crossover pipe, can't get to the 2nd bolt with it in the way.
  2. #2 Re: Coolant leaking out around bypass on LIM?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Yepp, you shouldn't have much of an issue if that's where it's leaking. crossover is just 4 bolts total and comes off. can you get to the bolts on the horizontal plate with an open ended wrench? could drain some coolant from the radiator to remove coolant from the LIM, back off those bolts on the coolant cover, add some RTV, then seal it back up and let it dry.
    Or as you mentioned, remove crossover pipe, remove coolant plate, add some RTV around the sides and then bolt back into place. Shouldn't need much RTV at all to clear up the issue.
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  3. #3 Re: Coolant leaking out around bypass on LIM?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I'd buy the gasket for it I think I have a extra new one in my spare gasket box lol.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  4. #4 Re: Coolant leaking out around bypass on LIM?
    Sep 2015
    IL
    I tightened the bolts down more, we'll see if that does it. I did replace the gasket when I did the LIM. The coolant was coming out around all sides so I probably didn't tighten em enough to begin with, although they are pretty tiny so I can't imagine they'd have that high of a torque spec. If it still leaks I guess RTV it is.
  5. #5 Re: Coolant leaking out around bypass on LIM?
    Jul 2015
    Jamestown, NY
    Did you torque them?
  6. #6 Re: Coolant leaking out around bypass on LIM?
    Sep 2015
    IL
    No I couldn't find a torque spec, so I just tightened them more. It's probably somewhere in the service manual but I didn't feel like searching forever to find it
  1. Coolant Leaking...again!
    By jenmelo in forum General Grand Prix Discussion
    Last Post: 11-18-2012, 06:34 PM
  2. Coolant Leaking Bad!
    By Ralphie in forum General Tech Discussion
    Last Post: 02-12-2011, 03:07 PM
  3. Leaking Coolant
    By nav in forum Introductions/Noob Questions
    Last Post: 07-19-2010, 03:55 AM
  4. leaking coolant
    By rdicarlo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 10:04 AM
