your dash blacking out when the key it turned to crank is 100% normal. if you hear a click from the dash the starter is failing, or bad ground or battery cable. loose starter wires. time to look around.
test the little wire on the starter when the key is turned to crank, it should light up a test light. if it dont light up, your issue is larger.
