Thread: Changing that oil filter. I need tips
Results 1 to 20 of 31
  1. #1 Changing that oil filter. I need tips
    GT Level Member Z28's Avatar
    Oct 2008
    Omaha, NE
    So i haven't even been under my car yet, but i was looking down in the engine bay and saw the oil filter . Looks to be in a weird spot.
    Is it that hard to get at, or was it just the angle I was looking at it. Looks like part of the front suspension is in the way.
    Oil change is coming up and I always do it on a lift with the oil tray underneath, just wanted to make sure i don't make a mess everywhere in their shop.
    Thanks
  2. #2 Re: Changing that oil filter. I need tips
    Oklahoma
    Moved to the correct area.
  3. #3 Re: Changing that oil filter. I need tips
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Just turn the wheels to the right and it's easily accessible through the wheel well.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: Changing that oil filter. I need tips
    Charles City, IA
    Yeah its not hard to get to. I don't even turn the wheels. I just reach up from the bottom.
    SMGPFC Two Nipple General
  5. #5 Re: Changing that oil filter. I need tips
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Z28 View Post
    ur lookin at it wrong!
  6. #6 Re: Changing that oil filter. I need tips
    Nov 2008
    Cedar Rapids, IA
    Haha no worries man, it's a very accessible filter. Get at it!
  7. #7 Re: Changing that oil filter. I need tips
    Barksdale AFB, LA
    The control arm is a little bit in the way. It will get some oil on it, but that's about it.
    2009 Subaru Impreza WRX STI
  8. #8 Re: Changing that oil filter. I need tips
    Donating Users
    W-S, NC
    It's not hard. I hate changing the oil filter on my wifes "Crapalier", makes the impala seem like a cake-walk.
  9. #9 Re: Changing that oil filter. I need tips
    I live here. UR LOSN's Avatar
    Rockford, IL
    a little fact for you. you can use an oil filter from 98-99 Chevy Blazers... they are longer, and will offer more filtration.
    I have used them since I found out way back when.... and really like them.
  10. #10 Re: Changing that oil filter. I need tips
    Barksdale AFB, LA
    Quote Originally Posted by UR LOSN View Post
    Should be able to use any filter from the 4.3L. S-10s, Silverados, Blazers, etc.
  11. #11 Re: Changing that oil filter. I need tips
    Donating Users
    W-S, NC
    Quote Originally Posted by Sabrewings View Post
    Would you have to add more oil to the crankcase due to the larger filter?
  12. #12 Re: Changing that oil filter. I need tips
    Hoffman/Schaumburg, IL
    Stock size GM filter(avalible at Murrays and others) : PF47
    Extended size GM filter(avalible at Murrays and others) : PF52
  13. #13 Re: Changing that oil filter. I need tips
    Barksdale AFB, LA
    It's not that much larger. I usually only use about 4.5qts. Now I use about 4.6-4.7 qts. I just fill it until it's at the top of the hash marks. Then I check it the next morning, and it usually never moves.
  14. #14 Re: Changing that oil filter. I need tips
    TDCRacing
    Guest
    It hold maybe 4 oz more
  15. #15 Re: Changing that oil filter. I need tips
    Rockford, IL
    normal Mobil1- M1-101
    Longer Mobil1- M1-201
    two can play at that game!
  16. #16 Re: Changing that oil filter. I need tips
  17. #17 Re: Changing that oil filter. I need tips
    Oct 2008
    Omaha, NE
    Ok thanks guys. I went and got the oil and i they were out of the pf47 so i went ahead and went with the pf52.
    so.....4.5 qts is what it takes?
  18. #18 Re: Changing that oil filter. I need tips
    QCA, IA
    yeah, 4.5 is the spec, but mine takes 5 to the top of the full range (with the longer filter, which does hold a little more).
  19. #19 Re: Changing that oil filter. I need tips
    GT Level Member 40th GP's Avatar
    Utah
    I don't mean to resurrect an old post, but I just changed my oil and could not find any info if the longer filter would work, so I went with the shorter filter, and just now found this. So the longer filter actually does fit in a supercharged car? There is not much room left in there, and I was worried about the longer filter maybe hitting on suspension travel. Is anyone using the longer filter without any problems on the supercharged?
  20. #20 Re: Changing that oil filter. I need tips
    It's alright to bring back old posts if your question or comment is worthwhile IMO...its the people that say pointless crap unrelated.
    As for your answer, AC Delco did make a PF52 or PF52E filter but it was discontinued last I checked and if used on our cars, they worked...but like you said...suspension travel. I've seen a few WBody's that have tore their filter to kingdom come because all their mounts weren't in good shape. I'd stick with just a PF47 or the equivalent...I use a K&N HP7001...or 7002...whatever it is.
  1. Thinking of changing oil
    By GTP4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2008, 04:00 PM
  2. changing supercharged oil
    By nemesis in forum General Tech Discussion
    Last Post: 08-06-2008, 12:27 PM
  3. Changing the Spark plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:24 AM
  4. Changing headlights
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 02-26-2008, 08:56 PM
