Thread: Lots of cranking on cold start?
Results 1 to 8 of 8
  1. #1 Lots of cranking on cold start?
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    Every morning when I start the car, it cranks for a while and seems to barely catch, but once it does it runs great. After that the car starts great every time, just after it sits. Brand new battery and alternator. Any ideas?
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  2. #2 Re: Lots of cranking on cold start?
    hangover park IL
    5 gallons of gas and a match
    ~James~ Psychotic Gearhead
  3. #3 Re: Lots of cranking on cold start?
    Apr 2015
    Illinois
    I was thinking more along the lines of a bad ICM or something, not ready to torch it just yet lol.
  4. #4 Re: Lots of cranking on cold start?
    I'd maybe check fuel pressure because the 04+ have the regulator on the pump. If that is part of the problem you'd see a drop off in fuel pressure right away after you prime it but once it's running it really doesn't matter.
    And dirty throttle bodies and MAF sensors can contribute to this issues.
  5. #5 Re: Lots of cranking on cold start?
    hangover park IL
    next time cycle the kjey on twice before turning it on and cranking so the fuel system builds pressure, the rails may be boiling empty and you crank a while while they fill. my 04 will extended crank if I don't let the pump prime for the full 2 seconds before I turn to the start position
  6. #6 Re: Lots of cranking on cold start?
    Apr 2015
    Illinois
    I'll try it tomorrow. Thanks guys
  7. #7 Re: Lots of cranking on cold start?
    Apr 2015
    Illinois
    Turned the key on and waited, and tried to start it... It was worse than ever. It almost didn't start, but when it did it was chugging and running like ****. Shut it off, tried again, and it barely even cranked, just fired right up
  8. #8 Re: Lots of cranking on cold start?
    Apr 2015
    Illinois
    Cycled it twice this morning and it started up fine. I guess that was the problem after all. I can do this for now obviously, but the permanent fix would be a new fuel pump, right?
  1. 2002 GTP Stalled at Cold Start; Now Won't Start at All
    By Nick8478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2015, 04:51 PM
  2. Extended cranking during cold stops (Particularly in Hot Weather)
    By gamefreak in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-24-2013, 12:27 AM
  3. Car will not start but is cranking
    By Corey Djcoreyt Tindal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2012, 08:58 AM
  4. e85 cold start
    By gtpsleeper in forum PCM Tuning
    Last Post: 01-03-2012, 12:35 PM
  5. cold start help needed
    By onetyme77 in forum General Tech Discussion
    Last Post: 11-29-2011, 09:15 PM
