Thread: Extended cranking during cold stops (Particularly in Hot Weather)
Results 1 to 10 of 10
  1. #1 Extended cranking during cold stops (Particularly in Hot Weather)
    Mar 2013
    Gulf Coast
    If I let my car sit during for a day and then start it (particularly in hot weather) I have an issue with excessive cranking. Takes at least 10 seconds if not more, almost like it doesn't want to start. After its started I have no trouble starting the car back up regardless of how many times.
    Also noticed the car is sometimes jerky when driving slowly through a parking lot. Watching the tachometer it does fluctuate some.
    Did a Tune-Up which included Air and Fuel Filters as well as new AC Delco Iridium Plugs.
  2. #2 Re: Extended cranking during cold stops (Particularly in Hot Weather)
    Omaha, NE
    Check for a vac leak.
  3. #3 Re: Extended cranking during cold stops (Particularly in Hot Weather)
    Did you also change the plug wires? I'd suggest cleaning the throttle body and maf sensor on top of your tune up. If the conditions continue, check fuel pressure when cold. It might be bleeding down and taking am moment to repressurize on the cold/sitting for a while starts
  4. #4 Re: Extended cranking during cold stops (Particularly in Hot Weather)
    Mar 2013
    Gulf Coast
    Already checked for a vacuum leak and there is none.
  5. #5 Re: Extended cranking during cold stops (Particularly in Hot Weather)
    Omaha, NE
    If you checked what bill said to check, and nothing resolved it, something else to look into would be the crank position sensor.
  6. #6 Re: Extended cranking during cold stops (Particularly in Hot Weather)
    Mar 2013
    Gulf Coast
    However will clean the MAF and Throttle Body as well as check the IAC. If none of those help check the Fuel Pressure. Appears to me the plug wires should still be good but may check that out.
  7. #7 Re: Extended cranking during cold stops (Particularly in Hot Weather)
    maybe a the fpr "fuel pressure regulator" has gone bad.
  8. #8 Re: Extended cranking during cold stops (Particularly in Hot Weather)
    Short version..
    Listen to Bill.
  9. #9 Re: Extended cranking during cold stops (Particularly in Hot Weather)
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Quote Originally Posted by BillBoost37
    Had the same issue on the 2001 and it was the fuel line fitting where it connects to the fuel rail. Looked fine, but if you wiggled it you could see the fuel dribble out. Fuel line is is the one on the fuel rail closest to the firewall, the forward connection is the return line. Dorman makes a repair kit, 800-059 for 3/8" line, 800-060 for 5/16".
    The fuel system stays pressurized for a quick start. If pressure bleeds off due to a leak, the fuel pump needs to rebuild the pressure before the engine will start, leading to longer crank times.
  10. #10 Re: Extended cranking during cold stops (Particularly in Hot Weather)
    Mar 2013
    Gulf Coast
    Seems like its running fine now. Couldn't find any leak as far as I could tell. My mechanic said that sometimes I just need to turn car on for a few seconds to build fuel pressure . Nothing to get too alarmed over as far as that remedies the problem with the cranking. That or the issue starts affecting my mileage and so on.
    I think a lot of the problem was since the car doesn't get much heavy use. Once I started driving my car a lot more and tried that tip it seems to have dealt with the problem. I only put 2,000 on car since February and before that it sat at a car lot of a year or so. The car getting used more often and some good ol' highway driving is helping.
  1. Extended cold air intake.
    By JT2002GTP in forum General Tech Discussion
    Last Post: 05-20-2013, 06:17 PM
  2. cold weather brings cold engine
    By Garrett Mofford in forum Engine
    Last Post: 12-31-2012, 08:45 PM
  3. Cold weather starting!!
    By Madness in forum General Tech Discussion
    Last Post: 02-28-2011, 02:55 PM
  4. Cold Weather and Speakers
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2011, 06:31 AM
  5. Washing Your Car in Cold Weather
    By Traeger2591 in forum Off Topic Discussion
    Last Post: 01-12-2010, 11:06 AM
