Thread: FINALLY ABOUT TO INHSTALL MY FSIC! Couple questions...
Results 1 to 19 of 19
  1. #1 Re: FINALLY ABOUT TO INHSTALL MY FSIC! Couple questions...
    they tend to be re usable. then again, depending on how small a pulley your running, about a 3.1 -3.2 stock injectors max out. thats when you get 42 lb's.
    its best to have a tuner for all this too.
    you need to figure out how your fmhe will be mounted and the pump mount. i made mine from a strap of old metal bolted under the horn bracket bolt, pump came with a exhaust band clamp on it for a mounting location on the pump.
  2. #2 Re: FINALLY ABOUT TO INHSTALL MY FSIC! Couple questions...
    SE Level Member brokeazfunk's Avatar
    Aug 2013
    Phoenix Az
    Oh crap! that reminds me, I need to rent a pulley puller to move my pulley to another M90 I picked up. I was going to drop to a 3.2 but i think I will stay with the 3.4 that I have now. I dont need a drag car and dont want to have to change injectors unless one goes bad.
    Now I need to find that thread that shows what size belt you need for a FSIC and a 3.4 pully.
  3. #3 Re: FINALLY ABOUT TO INHSTALL MY FSIC! Couple questions...
    i did this mod to my coil bracket, worked like a charm, i used a angle grinder with a 1 mm thick 4 inch cutting wheel. http://www.grandprixforums.net/threa...-BillBoost-way
  1. Couple AC Questions
    By SomeDudeAtHome in forum General Tech Discussion
    Last Post: 08-24-2013, 09:52 AM
  2. New here, couple questions.
    By osiris94ej in forum Introductions/Noob Questions
    Last Post: 11-16-2012, 10:07 AM
  3. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  4. A couple of questions.
    By Enjoijoe in forum General Tech Discussion
    Last Post: 04-12-2009, 07:56 PM
  5. couple questions on my gt
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2008, 08:58 PM
