Thread: high cold start Idle
Results 1 to 10 of 10
  1. #1 high cold start Idle
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    So I did a search and found a few threads on high cold start idles. Not much really came out of the threads and they died. Maybe I'm missing something.
    I just took a few videos of both my junk cars. First one is my 99. Top swapped, xp cam, Pre-00 N* TB and that's about it. It idles right around 1100-1200 where it should be from what I've read and such. This car hasn't been started in at least 3 days.
    https://youtu.be/9hlGbX1NdaU
    Now my 03 is below. I/C. 00+ N*, stock cam, blah blah . It started doing this months ago but after it warms up it's perfectly fine and idles ok. I did take out the IAC last night and cleaned it. It wasn't bad. Both tunes on the car haven't had any cold start idle things changed in the tune. I checked both of them last night. Everything else is fine when it warms up.
    https://youtu.be/7JaUj7fpeoU
    Why is my 03 idling higher when it's cold?
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  2. #2 Re: high cold start Idle
    theres settings in the pcm for cold start rpm's, temp vs rpm iirc. colder it is higher the idle speed.
  3. #3 Re: high cold start Idle
    looks normal to me.
  4. #4 Re: high cold start Idle
    Aug 2011
    Gahanna, Ohio
    Yes Scotty I know that. I already checked that. They are the stock values on both tunes/bin files.
    Both cars are at the same ambient temp. I took the videos within minutes of each other yesterday.
    But going back to my original post. Why does the 03 idle higher than the 99 at a dead cold start?
    Edit - Also, I particularly don't like waiting 10 minutes before I want to put the car in reverse to go to work. Cars don't like it when you go from park to reverse when the car is idling 1300 rpm's.
  5. #5 Re: high cold start Idle
    tach is wrong then? use a scanner to show the rpms, not the cluster.
  6. #6 Re: high cold start Idle
    Aug 2011
    Gahanna, Ohio
    it's 1400 on my scan master....The tach is not wrong. It's idling high. After it warms up. It's fine.
  7. #7 Re: high cold start Idle
    Aug 2011
    Gahanna, Ohio
    Nope. somehow i'm a tard (shocker eh?). I thought I had them side by side but I didn't.
    my 99 bin file has a slightly lower idle table than my 03. The 03 has air pump on and air pump off. Any idea what that is? - Edit - Cali emissions crap...
  8. #8 Re: high cold start Idle
    vac leak maybe.
  9. #9 Re: high cold start Idle
    i seen that, but didnt take a screen shot of it. how many bins do i have? lol
  10. #10 Re: high cold start Idle
    Aug 2011
    Gahanna, Ohio
    well I ended up dropping the idle on the 03 down a few hundred RPMS's. Seems to have helped but the car has only been off for 4 or so hours. The test will be in the morning.
  1. 2002 GTP Stalled at Cold Start; Now Won't Start at All
    By Nick8478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2015, 04:51 PM
  2. warm/hot start HIGH rev idle/ sticking throttle??
    By rschap1 in forum General Tech Discussion
    Last Post: 04-03-2012, 01:26 PM
  3. Bucking on acceleration and stumbling idle at cold start
    By 1999GrandPrix in forum General Tech Discussion
    Last Post: 02-08-2012, 02:21 PM
  4. why is my idle so low on cold start and sometimes fully warm?
    By 04silvercompg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2012, 02:49 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
