Thread: Reduce power
Results 1 to 12 of 12
  1. #1 Reduce power
    Mar 2016
    Gran prix gran supercharged engine starts up and runs for about 10-20
    Secs then sets a po68 code and then reduce power tracksion control I replaced the mad sensor and it still happens someone please help
    Sent from my Z970 using Tapatalk
  2. #2 Re: Reduce power
    thats not a full code. and mad sensor? you must mean map or maf....
    and what you driving? year make miles......
  3. #3 Re: Reduce power
    Donating Users moddman's Avatar
    Midwest
    Dtc p0068
    The ECM compares throttle position to expected engine load based on MAF and MAP sensor inputs. If the ECM determines that the current load and throttle position are not consistent with the expected load and throttle position, DTC P0068 is set.
    TPS sensor failure was common with GM. When the sensor fails the ECM puts the engine in safe (reduced power) mode.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  4. #4 Re: Reduce power
    GXP Level Member
    Mar 2015
    Tomball
    He's got a vacuum leak to the MAP.
    the P0068 is the MAF/MAP correlation error.
  5. #5 Re: Reduce power
    Mar 2016
    The engine is a 3.8 supercharged 2006 gran prix with 242,000 miles.I changed the mad sensor and the code po60 happen again the it showed up reduced power traction control.I had to clear the code to get full power back
  6. #6 Re: Reduce power
    Mar 2016
    that is mass air sensor and code po68
  7. #7 Re: Reduce power
    proof read please, help us help you, i have no clue still what part you changed, or the code.
  8. #8 Re: Reduce power
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by squatdemon2001 View Post
    No. It is the MAP and MAF Correlation error. You have a vacuum leak to the map sensor or a broken line to the sensor. I dealt with this code for months only with help here to find that I had a checkvalve in the system that didn't allow boost to the MAP.
    Basically the MAP and the MAF don't jive and the PCM shuts you down to keep you from killing the engine.
    I will bet dollars to doughnuts yOu have a leak in the line going to the MAP sensor.
    Jeff
  9. #9 Re: Reduce power
    Quote Originally Posted by J57ltr View Post
    Jeff
    i recall this battle...ford parts on a GM NOT good lol
  10. #10 Re: Reduce power
    GXP Level Member
    Mar 2015
    Tomball
    Yeah it was a hell of a struggle for a really odd problem. Now I've got to replace the lines since I have had at least 3 times where the the vacuum line has broken or cracked and given me the same issue. I must have bought the roll of vacuum line that the store has had since it opened and it's already dry rotted lol.
    Jeff
  11. #11 Re: Reduce power
    Mar 2016
    Ok I will check it out.thanks
  12. #12 Re: Reduce power
    GXP Level Member
    Mar 2015
    Tomball
    OP states it was a vacuum leak, fixed and everything fine now.
    Jeff
  1. HELP!!! Reduce Engine Power, ABS/Traction Control Disabled...
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 01-29-2014, 11:09 PM
  2. Reduce Engine Power
    By megpie in forum General Grand Prix Discussion
    Last Post: 12-08-2013, 10:33 PM
  3. Multiple eng codes and reduce eng power
    By Mr fix it in forum Introductions/Noob Questions
    Last Post: 04-21-2013, 02:10 PM
  4. reduce engine power / service traction system
    By p5773566 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 06:56 PM
  5. reduce engine power warning
    By rochaedkj in forum General Tech Discussion
    Last Post: 07-12-2009, 06:24 PM
