Also check the current sensor around the negative battery cable as it is used in the charging system. It is normal for the battery voltage to vary between 12.5 and 15.1, but not to get the charging system failure. The current sensor tells how much the system is drawing from the battery and adjusts the alternator accordingly.
Jeff
