Thread: Pulley size question
Results 1 to 20 of 30
  1. #1 Pulley size question
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    So my setup is in my signature and I was curious when you drop pulley size from like a 3.4 to a 3.3 would you need alot more fuel or change the tune? Or is it possible for it to work I've only ever had a 3.4 and I've always had 0kr and the air fuel is good.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #2 Re: Pulley size question
    May 2008
    Schuyler, NE
    It will be fine. Your maf reads you have more air coming through, so it will compensate with more fuel.
  3. #3 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    Do you think I could get away with a 3.3 pulley or could the kr go through the roof? How much is a .1 of a drop as far as boost/power? I did a top swap and only ever had a 3.4 on the car never even had a stock 3.8 or whatever so I have no idea lol.
  4. #4 Re: Pulley size question
    That's the hope anyway, maybe.
    But it's still possible to run lean if the maf calibration isn't just right, he might hit a certain maf hz where it could lean it out. But I doubt you'll gain more than 1 psi with the small pulley drop.
  5. #5 Re: Pulley size question
    May 2008
    Schuyler, NE
    If you have 0kr, you probably can drop to a 3.3. It won't make much of a difference in boost level or power. You probably can't feel a difference without a dyno.
    I'd try it. If it doesn't work, go back to a 3.4.
  6. #6 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    If it's that little of a drop could it even go that lean? So your saying not even a noticeable difference in power?
  7. #7 Re: Pulley size question
    May 2008
    Schuyler, NE
    If his afr is good now, dropping .1" on the pulley size isn't going to change anything.
  8. #8 Re: Pulley size question
    May 2008
    Schuyler, NE
    Quote Originally Posted by Tonkin2000GT View Post
    Maybe 5-10 hp.
  9. #9 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    Okay because I had 0kr with a plog setup and I just now installed my slp headers so I figured I could probably get away with it and like you said if not I'll just put the 3.4 back.
  10. #10 Re: Pulley size question
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    I'm currently running a 3.2 on my setup with about 6* total.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  11. #11 Re: Pulley size question
    Quote Originally Posted by torq455 View Post
    6* of kr? thats no good.
  12. #12 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    6* of kr?
    Sent from my SM-G920V using Tapatalk
  13. #13 Re: Pulley size question
    Where is chip?
  14. #14 Re: Pulley size question
    no kr chip.....dead fuel pump caused this one. so it must of got a touch right lol
  15. #15 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    Who's motor is this?
  16. #16 Re: Pulley size question
    thats my l67. had rockers and a 3.4, headers. fuel pump took a crap leaned it out and hello you sob you chip. it popped at the top of second gear at the shift. it made some funny sounds, and i knew it was hurt asap.
    funny part was i planning on swapping it out 2 or 3 days later anyways, plan was to have a running spare. my brother saw it like this, i was cheating on my engine building the new one, so it dumped me.......just like a scorn chick lol
  17. #17 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    ****ty did you have gauges or did it just happen that quick?
  18. #18 Re: Pulley size question
    i had the t app running saw nothing, it was tuned pretty good, no kr at all. wish i had the wideband hooked up, but that got bought and installed with the new engine.
    didnt figure out the pump was bad till a 1000 miles later on the new engine too. i had it tuned in rough and the new pump made my ltft go from -0.8 to -2.8.
  19. #19 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    What does the t app show? Is it like a aeroforce? I'm assuming that happened during wot? When your reading stft and ltft is that really critical to moniter all the time? Is it normal for them to fluctuate alot? I know the closer to 0 is where you want it to be but how critical is that?
  20. #20 Re: Pulley size question
    fuel trims are read off the narrow band o2, so not 100% accurate. but works.
    neg numbers are rich, pos are lean. wot the ltft will lock in and stay at one number. 0,0 is the goal, ideal you want it to run -5 and lower at idle and cruising around under normal driving. its better to be a tad rich as you go wot.
    if i get my ltft to lock in at -1. something wot i leave it like that. i rather a tad more fuel then not. right now im locking in at -3.1 wot, need to lean it out just a bit more.
    stft should be close to 0.0 at idle, and lock in at 0.0 wot. idle and normal driving it will dance around.
  1. Noob Question. S/C Pulley size???
    By Ahaas96 in forum Introductions/Noob Questions
    Last Post: 11-07-2013, 01:50 PM
  2. Another pulley size question =D
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2011, 07:08 PM
  3. Stuppuid pulley size question
    Last Post: 08-13-2010, 04:34 PM
  4. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  5. belt size question for 2.8 pulley
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2009, 07:33 PM
