Thread: Pulley size question
Results 1 to 20 of 30
  1. #1 Pulley size question
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    So my setup is in my signature and I was curious when you drop pulley size from like a 3.4 to a 3.3 would you need alot more fuel or change the tune? Or is it possible for it to work I've only ever had a 3.4 and I've always had 0kr and the air fuel is good.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #2 Re: Pulley size question
    May 2008
    Schuyler, NE
    It will be fine. Your maf reads you have more air coming through, so it will compensate with more fuel.
  3. #3 Re: Pulley size question
    Quote Originally Posted by GTPpower View Post
    That's the hope anyway, maybe.
    But it's still possible to run lean if the maf calibration isn't just right, he might hit a certain maf hz where it could lean it out. But I doubt you'll gain more than 1 psi with the small pulley drop.
  4. #4 Re: Pulley size question
    May 2008
    Schuyler, NE
    If his afr is good now, dropping .1" on the pulley size isn't going to change anything.
  5. #5 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    Do you think I could get away with a 3.3 pulley or could the kr go through the roof? How much is a .1 of a drop as far as boost/power? I did a top swap and only ever had a 3.4 on the car never even had a stock 3.8 or whatever so I have no idea lol.
  6. #6 Re: Pulley size question
    May 2008
    Schuyler, NE
    If you have 0kr, you probably can drop to a 3.3. It won't make much of a difference in boost level or power. You probably can't feel a difference without a dyno.
    I'd try it. If it doesn't work, go back to a 3.4.
  7. #7 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    If it's that little of a drop could it even go that lean? So your saying not even a noticeable difference in power?
  8. #8 Re: Pulley size question
    May 2008
    Schuyler, NE
    Quote Originally Posted by Tonkin2000GT View Post
    Maybe 5-10 hp.
  9. #9 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    Okay because I had 0kr with a plog setup and I just now installed my slp headers so I figured I could probably get away with it and like you said if not I'll just put the 3.4 back.
  10. #10 Re: Pulley size question
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    I'm currently running a 3.2 on my setup with about 6* total.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  11. #11 Re: Pulley size question
    Quote Originally Posted by torq455 View Post
    6* of kr? thats no good.
  12. #12 Re: Pulley size question
    Dec 2008
    Alabama
    Guess I should have stated that's not kr, rather total WOT timing.
  13. #13 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    6* of kr?
    Sent from my SM-G920V using Tapatalk
  14. #14 Re: Pulley size question
    Where is chip?
  15. #15 Re: Pulley size question
    no kr chip.....dead fuel pump caused this one. so it must of got a touch right lol
  16. #16 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    Who's motor is this?
  17. #17 Re: Pulley size question
    thats my l67. had rockers and a 3.4, headers. fuel pump took a crap leaned it out and hello you sob you chip. it popped at the top of second gear at the shift. it made some funny sounds, and i knew it was hurt asap.
    funny part was i planning on swapping it out 2 or 3 days later anyways, plan was to have a running spare. my brother saw it like this, i was cheating on my engine building the new one, so it dumped me.......just like a scorn chick lol
  18. #18 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    ****ty did you have gauges or did it just happen that quick?
  19. #19 Re: Pulley size question
    i had the t app running saw nothing, it was tuned pretty good, no kr at all. wish i had the wideband hooked up, but that got bought and installed with the new engine.
    didnt figure out the pump was bad till a 1000 miles later on the new engine too. i had it tuned in rough and the new pump made my ltft go from -0.8 to -2.8.
  20. #20 Re: Pulley size question
    Jul 2015
    Jamestown, NY
    What does the t app show? Is it like a aeroforce? I'm assuming that happened during wot? When your reading stft and ltft is that really critical to moniter all the time? Is it normal for them to fluctuate alot? I know the closer to 0 is where you want it to be but how critical is that?
  1. Noob Question. S/C Pulley size???
    By Ahaas96 in forum Introductions/Noob Questions
    Last Post: 11-07-2013, 01:50 PM
  2. Another pulley size question =D
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2011, 07:08 PM
  3. Stuppuid pulley size question
    Last Post: 08-13-2010, 04:34 PM
  4. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  5. belt size question for 2.8 pulley
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2009, 07:33 PM
