Thread: Low trac& tcs flickering
Results 1 to 9 of 9
  1. #1 Low trac& tcs flickering
    Feb 2016
    Jacksonville Fl
    I'm not sure where to post this
    Bought this car about 3 weeks ago fixed a few sensors and no codes since. But the TCS OFF light has been on since I bought it. Hasn't gave me a problem. Just this morning the Low Trac and TCS starts flikering only when moving, makes a pluse in the brake peddle when I push the brakes. Any ideas?
    Sent from my LG-H634 using Tapatalk
  2. #2 Re: Low trac& tcs flickering
    Feb 2016
    Jacksonville Fl
  3. #3 Re: Low trac& tcs flickering
    could be a bad ebcm.
  4. #4 Re: Low trac& tcs flickering
    Jul 2010
    Coquitlam,BC,Canada
    I had the same symptoms a few weeks after changing my right front wheel bearing. I suspect that I pinched a wire during install, and just unplugged the sensor as the ABS pulsing during the first few minutes of driving (until the ABS disabled itself) was getting annoying. My ABS light is on also. Is yours? The way your light flickers could be a bad wheel bearing/sensor.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Low trac& tcs flickering
    Feb 2016
    Jacksonville Fl
    Nope no abs light on. Just the flickering of the lights in the video.
  6. #6 Re: Low trac& tcs flickering
    getting it scanned will lead you to the issue 99% of the time.
  7. #7 Re: Low trac& tcs flickering
    Feb 2016
    Jacksonville Fl
    Funny thing is I normally full up for fuel when the chime comes on low fuel light . Went further than I normally do and thought I would full up in the morning.This morning when the Low Trac & TCS flickering the info center started acting up also . It would read 0 then back to normal, back 0. And that's on any setting oi life, fuel range etc. Not sure of this is related.
  8. #8 Re: Low trac& tcs flickering
    Jul 2010
    Coquitlam,BC,Canada
    I wonder if the DIC is crapping out.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: Low trac& tcs flickering
    Feb 2016
    Jacksonville Fl
    I hope it is just the DIC crapping out.. Lol
  1. Flickering DIC when cold
    By Centauri in forum Audio, Security & Visual Electronics
    Last Post: 08-21-2016, 01:06 PM
  2. DIC flickering (not flashing)
    By mechcd in forum Audio, Security & Visual Electronics
    Last Post: 03-24-2012, 11:37 PM
  3. Flickering DIC
    By jeepers in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2011, 09:24 AM
  4. HID's flickering?
    By JESSEGOTTA GP GT in forum Visual/Body Modifications
    Last Post: 02-25-2010, 01:31 PM
  5. HID flickering... is this normal?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 06-29-2009, 09:15 AM
