Thread: Water
Results 1 to 12 of 12
  1. #1 Water
    May 2012
    Canada , Sarnia
    Today I was going to clean the interior of the car and pulled the mats out and noticed to puddles on the passenger side of the car front seat and back seat I used my shop vac to get most of the water out what could be the cause of this
  2. #2 Re: Water
    http://www.grandprixforums.net/threa...-Permanent-Fix this will cause it to leak, 8 dollar fix.
  3. #3 Re: Water
    Jan 2014
    AR
    It is also possible (especially since you have water in the rear footwell too) that the butyl rubber sealant which holds the plastic weather liner to a metal door shell has shrunken over time or been improperly reinstalled. This can result in water coming over the sill trim from underneath the door trim panels and is easy to spot, and to fix with the door panel off. Theres a water flow path inside the door and the liner seal is important because the window trim does not stop water from flowing through the door. Check drain holes at bottom of door shells as well, and clear if clogged. I can tell everyone is getting rain like we have lately or worse. Lotsa water leaks!
  4. #4 Re: Water
    Apr 2011
    Elk Rapids, Michigan
    I had the same issue. The fix that Scotty gave did the trick for me. Part is cheap and readily available on Amazon and eBay for under $10. You can add a cabin air filter at the same time if you like. The one from a Regal G's will fit.
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  5. #5 Re: Water
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Quote Originally Posted by idrivejunk View Post
    I think this one of my issues because i have water on the drivers floor under the mat, carpet is wet all the way up to the point underneath the speaker in the door.
    I did have water on the passenger side, on top of the mat. Put the water deflector under the cowl and passenger side has been dry!
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  6. #6 Re: Water
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by ScottyDoggs View Post
    I can vouch for this, I do this to all my W-bodies now.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: Water
    if you park on a incline. like the back of the car is lower, the cowl leaks hits the front floor and travels to the rear, the body has openings so the water can travel to the rear no problem at all.
    while it gets to the back it passes and floods the airbag module, so if the airbag light is on, you now know why.
  8. #8 Re: Water
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    did you leave your window down during a storm ?
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  9. #9 Re: Water
    May 2012
    Canada , Sarnia
    installed the new deflector vaccumed the water now its still damp would a air mover help it to get dry
    http://www.tscstores.com/500CFM-SHOP...ER-P38519.aspx
  10. #10 Re: Water
    the foam holds a ton of water, even after you think you got it all out, i lifted my carpet up, propped up with some sticks, then had a box fan blowing on it to dry it up.
    i also used baking soda to kill the pond smell you maybe getting already. rub it in the top and bottom of the carpet, use a shop vac to clean it up after its dry.
    dont use your home vacuum, you might kill it, b/s is super fine and will get in places you dont want. car wash vacs work good for this clean up too.
  11. #11 Re: Water
    May 2012
    Canada , Sarnia
    just went and checked the foam underneath its wet going to buy that air mover and hopefully can dry it out
  12. #12 Re: Water
    i took 2 days of the fan treatment on warm summer days.
    my car got flooded in the winter time, i gutted the car and after i had removed as much as i could. hung the carpet in the garage, it took 2 weeks to drip dry.
  1. water?
    By helivancleef in forum Introductions/Noob Questions
    Last Post: 12-10-2013, 06:48 AM
  2. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  3. Do you run distilled water or water out of the tap in your cars?
    By Slick2500 in forum Off Topic Discussion
    Last Post: 10-14-2012, 10:59 AM
  4. Water in car
    By hockey101 in forum General Tech Discussion
    Last Post: 08-07-2011, 08:51 AM
  5. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
