2004 3.8 GT2
was having issues a week ago with starting the car. would only start with my foot on the brake. now it wont crank but all dash lights light up.
brand new battery didn't fix it. jumping it doesn't work.
ran power probe to starter and it started the car while someone else turned the key. this was done by both jumping the starter as well as just providing power with the power probe and grounding to the trans.
I cleaned all connections/wires to/from starter to no avail. rigged up a push button starter inside the cab and then got in the car to test. decided to try a key-only start and it fired up normally 3 times then stopped working. tried key to on and push button start and it fired up too. this morning, neither the key or button will fire the car although the starter turns strong with the push button.
2 months ago I had the typical cowl leak that fried the heater blower and relay. I replaced both of those as well as the ignition switch. although the blower still isn't working, the car started/ran perfectly until now.
help!
