I'll clean the TB too.
could my issue be related to the crank sensor behind the balancer? please say no!
ill check spark tonight to verify.
to check for spark you can pull and prop a plug wire over the coil terminal, a big blue spark will jump to the wire if its got spark.
the fuel rail has a black cap on it, take it off theres a valve inside looks like a tir valve stem. push the pin, gas should fly out with lots of pressure, turn key to run, then test. watch your eyes, fuel can fly if your pressure is good. i lay a rag over it, it still flys.
