Thread: Some more top swap questions! Yay!
Page 42 of 71 FirstFirst ... 32404142434452 ... LastLast
Results 821 to 840 of 1411
  1. #821 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    So how is the install coming along? What has been the biggest/worst part so far?
  2. #822 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    I cant get the f*ckn crank bolt off. Im so frusterated right now. Other than that just the headers were a real pain theres just no clearance for much of anything. Everything else has been fine
    Sent from my LG-D851 using Tapatalk
  3. #823 Re: Some more top swap questions! Yay!
    Apr 2015
    Quote Originally Posted by suitercrew View Post
    Ok. I was just curious for when I do mine. I'll focus more on those areas when I do mine. What was final torque spec you used for the rockers?
  4. #824 Re: Some more top swap questions! Yay!
    if you cant get it free, finish the top swap, run the one belt, you can drive it fine, hit a shop, ask them to zap it off for ya, snug it back up, go home swap the balancer
  5. #825 Re: Some more top swap questions! Yay!
    Oct 2015
    25ft lbs on the rockers seemed to work great
  6. #826 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya right now everything is done besides the front o2 and that stupid hb
  7. #827 Re: Some more top swap questions! Yay!
    Apr 2015
    Did you end up twisting the stock fuel line connections?
  8. #828 Re: Some more top swap questions! Yay!
    get it running, then hit up a garage with a real compressor and air gun is my guess.
    are you running out of air pressure fast? some times you need to let the air gun just hammer away for a while. a gun that large is gonna use up air pretty fast id think. if you got a little 30 gal tank, its never gonna cut it.
  9. #829 Re: Some more top swap questions! Yay!
    Oct 2015
    The whole fuel line is twisted but ya same concept
  10. #830 Re: Some more top swap questions! Yay!
    Apr 2015
    Gotcha.
  11. #831 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya so i can just hook up the main drive belt and it should be good to drive right?
  12. #832 Re: Some more top swap questions! Yay!
    yup, fine to drive, be a dog, but its safe.
  13. #833 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok. Just out of curiosity how would the car run without the front o2?
  14. #834 Re: Some more top swap questions! Yay!
    like crap.
    put it in, it fits, its just gonna hit the fire wall till you beat the wall in some.
  15. #835 Re: Some more top swap questions! Yay!
    Oct 2015
    Well i wanna just start the car now and make sure im not having a catastrophic head gasket leak or something
  16. #836 Re: Some more top swap questions! Yay!
    fire in the hole!!!!!
    turn the key to run, then go check your fuel rail for leaks and injectors, no leaks fire it up.
    if the o2 is not installed thats a good exhaust leak.
  17. #837 Re: Some more top swap questions! Yay!
    Oct 2015
    Okie
  18. #838 Re: Some more top swap questions! Yay!
    Apr 2015
    Take a video!!!! It will be a cool video to keep.
  19. #839 Re: Some more top swap questions! Yay!
    Oct 2015
    How long would the car have to run before i knew if there was a head gasket leak? Like does the tstat have to open first?
  20. #840 Re: Some more top swap questions! Yay!
    you put coolant in it right ? lol keep filling it up as its running and takes more.
    hows it running?
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
