Thread: Some more top swap questions! Yay!
Page 24 of 71 FirstFirst ... 14222324252634 ... LastLast
Results 461 to 480 of 1411
  1. #461 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    So scotty can i just use a puller and then the bolts you gave me the specs for yesterday right?
    Sent from my LG-D851 using Tapatalk
    Yes, been done a million times
    04 Comp G.
  2. #462 Re: Some more top swap questions! Yay!
    what ive been saying the whole time. its what i did, i own a puller, its got 3 sets of bolts, not one is close to fitting. buy the bolts in that thread.
    i had a issue finding them long enough. had to order and buy a bag of 25, but they still cost less then 3 bucks.
  3. #463 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    So if you have a bag of 25 bolts send him 3? Lol
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  4. #464 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ya send me some lol
  5. #465 Re: Some more top swap questions! Yay!
    id have to look for em, no idea where i put them no more......i do know 3 are with my puller tho lol
  6. #466 Re: Some more top swap questions! Yay!
    Oct 2015
    Lol ok let me just skim back and look at what spec bolts i need
  7. #467 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok m6x1.00 70-75mm length
  8. #468 Re: Some more top swap questions! Yay!
    60 mm works too, what mine are iirc. i know for sure they are less then 70.
  9. #469 Re: Some more top swap questions! Yay!
    Oct 2015
    And i only need 3 correct?
  10. #470 Re: Some more top swap questions! Yay!
    yes 3, and 3 washers for them too, or they can pull through the puller.
  11. #471 Re: Some more top swap questions! Yay!
    Oct 2015
    Mmmmmmm okie dokie i will probably try this tomorrow if i can find the bolts locally
  12. #472 Re: Some more top swap questions! Yay!
    Oct 2015
    So should i plug my coolant ports on my lim i forgot to get orings and figured this would be faster. It was two dimes and some.e jb weld?
  13. #473 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Weld them shut that's ghetto lol
  14. #474 Re: Some more top swap questions! Yay!
    Oct 2015
    I cant weld..
  15. #475 Re: Some more top swap questions! Yay!
    Jb weld or quicksteel and 2 dimes work fine... no need to spend money to have them welded jeez or just drill and tap them with npt plugs... I feel like you should of already looked and studied the several how to's that Bill has made and could of avoid several several repeat questions
    04 Comp G.
  16. #476 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I'd take it and have them welded it won't cost much it's the right way to do it
  17. #477 Re: Some more top swap questions! Yay!
    It's a waste of money to do it money bags. It's two coolant port not something major. do you think this is the first time someone's come up with that idea...no its been done time and time and time after time.. either drill and tap them or use the dime method, whichever floats your boat.
    Edit: now if he could weld himself then go for it but I sure as hell would pay what someone's gonna charge to turn on their welder to do it for you.
    04 Comp G.
  18. #478 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    LOL it might cost 10 bucks to have someone do it really? Vs having jb weld crack over time and hydro locking the motor? I'd spend the extra to be safe. Yeah it's been done and it works but it's your motor we're talking about smh.
  19. #479 Re: Some more top swap questions! Yay!
    Have you ever read or seen someone that had a issue doing either the plug or dime method? It's been done time after time there's a reason it's the cheap yet effect method. Most guys won't turn on there welders for $10 it's not worth it, how much did you pay. Obviously if you have a buddy of a buddy etc that doesn't count.
    04 Comp G.
  20. #480 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I don't care my motor hydro locked when it was a N/A idling in my garage from those coolant holes with the pos plastic upper intake. No need to risk it for something that dumb.
    Thats what happens...
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
