Quote Originally Posted by J57ltr View Post
IT'S NOT A SHORT. A short would mean that you would have power and ground connected together. You have an INTERMITTENT connection. That said there are some differences between 97' and 98' up harnesses. You will need to get a wiring diagram for both your 97' and whatever other year car you pulled the fusebox you pulled, and compare them. Chances are that there are a couple of wires that are different. It sounds as though you don't have a signal or power to the temp gauge.
I just went through this with another member on this forum and had a small fire and the only replacement harness is a 97' for a 97'. Tried talking him into switching to 98' and later but there were too many things to change in order to get it working.
I had a hell of a time with my Dad wanting to change his 00' truck with an 06' motor. I had to convince him to change engine parts from his 00' motor to work with the 06' engine and trans, as the differences were significant. Your kinda in the same boat where the 97' is different enough to have to check everything.
Don't use a haynes manual or chilton both are worthless as tits on a boar hog when it comes to a wiring diagram. I am sure someone on here has All Data that can send you a diagram.
Jeff
What he said ^
