Thread: L32,L26,L67,L36 Diffrences?
Results 1 to 20 of 21
  1. #1 Re: L32,L26,L67,L36 Diffrences?
    TDCRacing
    Guest
    Cool. So i'm going to be using a N/A intake. So what intake's are compatable. Since I am going to be using a N/A intake then that means it will have injector basses in the lim. I will be using Ported L67 heads wich also have injector bosses in them.
    Wich do I use? The ones in the head or in the LIM? How would I go about plugging the ones i am not using??
    Can I use a L67 lim with a N/A upper intake manifold? That would be ideal in my case.
    Thanks for any help with this.
  2. #2 Re: L32,L26,L67,L36 Diffrences?
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    I'm pretty sure O2 sensors and spark plugs use the same thread. O2 bung plugs might work. I'd just get a set of L36/L26 heads.
    Nope. Not that I know of.
    2009 Subaru Impreza WRX STI
  3. #3 Re: L32,L26,L67,L36 Diffrences?
    Donating Users chrisb's Avatar
    Bucyrus, OH
    you can just plug the extra holes, i had a link but i cant find where some one did this. i would prolly use the ones in the heads over lim. you could use the other holes and run meth/water into them.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  4. #4 Re: L32,L26,L67,L36 Diffrences?
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    What are you talking about? lol I was talking about the injector holes.
    And Yeah I already bought some heads with bigger valves...So that def not an option.
    Yeah I probably would just use the ones in the head.
  5. #5 Re: L32,L26,L67,L36 Diffrences?
    Donating Users Reflective Concepts's Avatar
    Feb 2008
    I believe he was giving size reference on what to use to gauge size to plug the holes. Example: thread them and use an o2 bung plug. (?)
    You could also just have a shop weld the injector holes shut. Might save you the aggravation of finding and threading plugs...
  6. #6 Re: L32,L26,L67,L36 Diffrences?
    Feb 2008
    San Diego, CA
    If I was planning a turbo build, I'd go L32 (first option) or L67 (second).
    Might as well do an aluminum L26 UIM:
    BonnevillePRO.com • View topic - L26 aluminum UIM on L36--Done! With results!!
    IMO the closer to the cylinder you inject the fuel, the better. But to plug the unused injector holes:
    A friend made those for me. I'm sure I could get him to make more. With these, you could keep the holes around and, as was suggested, consider some kind of alky injectors later.
    I would keep the n/a LIM, so you still have some runner length and don't lose all your low-end torque.
