Thread: Just changed lim, reduced power on display center
Results 1 to 6 of 6
  1. #1 Just changed lim, reduced power on display center
    Dec 2015
    Cadillac Michigan
    Just replaced lim on my 04 comp g. I found a broken vacuum plug, not sure where it came from. I think it may be the t under the supercharger, it's old, but I can take the line that runs out of it and it still has vacuum. I'm thinking it may be losing some vacuum, but not enough to make it so the car doesn't run. It will start for a few minutes, throttle doesn't work, then I get a reduced engine power in my display and car shuts off. I'm wondering if maybe the vacuum plug I found maybe needs to be hooked up somewhere but the vac line diagrams don't really show where any plugs should go. I am replacing the vacuum t real soon but just think it could be more than that. Any ideas? Car ran great prior to intake gasket change.
  2. #2 Re: Just changed lim, reduced power on display center
    Clear the check engine code, it's got to have one if it's going into reduce power mode.
    I'd even unplug the throttle body and make no pins are bent or damaged and plug it back in. Then fix the vacuum line and see if it runs better.
    Post pictures of the plug or line you are talking about, we may know it goes.
  3. #3 Re: Just changed lim, reduced power on display center
    Dec 2015
    Cadillac Michigan
    I'm just inpatient. About 15 minutes later car was running fine. Went to AutoZone and got that vacuum line right and now it's all good. Just couldn't miss work tomorrow lol. Now that that is done onto exhaust mods lol. Thanks for the input though.
  4. #4 Re: Just changed lim, reduced power on display center
    Dec 2015
    Cadillac Michigan
    Is there supposed to be a plug on the boost bypass selenoid?
  5. #5 Re: Just changed lim, reduced power on display center
    One side has a vacuum line going to it, the other is suppose to be open. The little foam piece on it always falls off.
  6. #6 Re: Just changed lim, reduced power on display center
    Dec 2015
    Cadillac Michigan
    Awesome. My foam is even in tact still. Thanks.
  1. Car saying reduced engine power.
    By Louie3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 06:10 PM
  2. reduced engine power display after replacing lim gasket
    By bromyk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2013, 11:30 AM
  3. Center display not working
    By vertebrate in forum General Tech Discussion
    Last Post: 07-27-2012, 11:59 PM
  4. reduced power message
    By chiana4477 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-15-2010, 06:41 AM
  5. Center Display Help
    By Forrest in forum General Tech Discussion
    Last Post: 03-06-2009, 09:58 AM
