Thread: Oil pressure gauge high
Results 1 to 14 of 14
  1. #1 Oil pressure gauge high
    Feb 2015
    california
    Just installed electrical oil pressure gauge and im getting high readings between 60 and 80. Any idea whats going on?
  2. #2 Re: Oil pressure gauge high
    Thats not abnormal in the least.
    Cold idle should be 60-70 and cold driving should be 65-80.
    Hot idle around 35-45 and hot driving around 55-65psi.
  3. #3 Re: Oil pressure gauge high
    Feb 2015
    california
    ive not seen it under 60
  4. #4 Re: Oil pressure gauge high
    Well, you never said that. Explaining things fully is only way for us to know what you want us to know.
    The numbers I said are still what you should be seeing give or take 5psi in some cases.
    Possible problems could be the gauge itself or the sending unit. Best way to find out is use a manual pressure gauge that you can just quick hook up and see what that says. If the manual gauge says somethings like I said, then you know the sending unit you have is likely faulty.
  5. #5 Re: Oil pressure gauge high
    Feb 2015
    california
    I never said anything about cold start you assumed that i just said 60 to 80. Lowest and highest at anytime. Gm told me lowest should be 60 for my car. So i guess its ok?
  6. #6 Re: Oil pressure gauge high
    If you are seeing 60 psi at hot idle you must have the worlds best 3800 ever made.
    I assume everything with someone who gives so little information. My numbers from my first post still stand and my second post also is something you should look into doing.
    No 3800 will have 60 psi of oil pressure with a heat soaked motor.
  7. #7 Re: Oil pressure gauge high
    Feb 2015
    california
    65 psi idle at 180 degrees.
  8. #8 Re: Oil pressure gauge high
    Nov 2013
    Wisconsin!
    Aren't you the one who posted the same thing on facebook? And got told your glowshift gauge is cheap......and not very accurate and not to worry.....
  9. #9 Re: Oil pressure gauge high
    i got a glow shift o/p gauge, its at 25 psi when the the engines off. does yours drop to zero car off? mine dont, its at 25 psi off.
    75 cold, 50 warm. its 25 psi to high cause the gauge is pos.
  10. #10 Re: Oil pressure gauge high
    Feb 2015
    california
    Quote Originally Posted by ScottyDoggs View Post
    Gauge is at zero when the car is off.
  11. #11 Re: Oil pressure gauge high
    Nov 2013
    Wisconsin!
    ^exactly.....cheap gauge. Use it for a baseline if something starts showing different then your gauges "normal" you know something is going on. But OP your gauge is crap. Hence why it's reading strange.
  12. #12 Re: Oil pressure gauge high
    heres my pos glow shift o/p
    this is warmed up at idle. just came off the hwy.
    its either the sender, or the gauge, or both. cheap is just that, cheap. 30 dollar gauge, lesson learned.
  13. #13 Re: Oil pressure gauge high
    Feb 2015
    california
    seems accurate like i said GM said no lower than 60
  14. #14 Re: Oil pressure gauge high
    Nov 2013
    Wisconsin!
    Your motor is fine. And you don't have 65psi at hot idle. /thread
  1. Oil Pressure too high???
    By Booba5185 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2015, 03:49 PM
  2. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  3. High Oil Pressure
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2009, 02:44 PM
