Thread: CamShaft thoughts
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 81
  1. #1 CamShaft thoughts
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    I want a CamShaft that will provide plenty of power from low-end to top end thru out the powerband(my new build will compliment the Cam very well)
    But yet i need a Cam that will idle around 700-800rpm or close to stock or at least somewhere in that tolerable comfortable range.
    I also need to be able to pass state emissions
    Im choosing from four Cams. ZZPs XP and XPZ and Intense Stage 2 and Stage 3. ZZPs VS Cam is decent but i want a cam with more power, you know....worth the time and money(minds well get the most out of the S/C while im at it)
    What CamShatft do you guys think would best fit my build ?
    Regal GS
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: CamShaft thoughts
    Jul 2012
    North Philly
    Im only choosing out of those CamShafts i stated
    Thanks........
  3. #3 Re: CamShaft thoughts
    XP cam should be alright.
  4. #4 Re: CamShaft thoughts
    S2x. The XP cam is more comparable to a S1x iirc.
  5. #5 Re: CamShaft thoughts
    Kemmerer, Wyoming
    I thought the xp cam did better at higher rpms
  6. #6 Re: CamShaft thoughts
    Quote Originally Posted by SgtMarshal View Post
    I said more comparable I never said either one was better than the other.
  7. #7 Re: CamShaft thoughts
    whatever is leading you to believe that those larger than stock cams will idle better at stock-ish idle RPM, you're wrong. usually you bump the idle UP a little bit to smooth it out.
    those cams may idle there, but the only reason you'd do it is to accentuate the lope of the cam...not to make sure you can tolerate the idle. you're thinking backwards.
  8. #8 Re: CamShaft thoughts
    Nov 2011
    NY
    Cams are simple IMO, go BIG or gone home! No sense doing all that work for a MIlD cam... Just doesn't make sense to me, lol
    thanks for listening...
    maybe, just maybe some day when I get time, I'll get my build into my engine bay
  9. #9 Re: CamShaft thoughts
    Buffalo
    Sweet. Another dead-horse beating Brb gotta get my club!
  10. #10 Re: CamShaft thoughts
    May 2008
    Schuyler, NE
    XPZ/thread.
    https://youtu.be/CRYIBSBEs4Y
    Holding idle at 900rpms in that video, as you can see. Very smooth. It runs smoother than my XP cammed car.
  11. #11 Re: CamShaft thoughts
    Nov 2011
    NY
    XPZ/thread.
    whaaaaaat no lopey idle??? Lolz...
  12. #12 Re: CamShaft thoughts
    Buffalo
    IS3 /life
  13. #13 Re: CamShaft thoughts
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I removed the cam in my car for weight reduction. Runs purrrrfect.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  14. #14 Re: CamShaft thoughts
    Jul 2012
    North Philly
    Yo that XPZ at idle is nice, not bad at all. Now will it pass state emissions?
  15. #15 Re: CamShaft thoughts
    Buffalo
    lol you're buying an aftermarket cam based solely on it idling like stock? HAHAHAHA
    any of the 3800 cams will idle smoothly if you can tune it - the exhaust will still be choppy. How choppy depends on the size of the cam.
  16. #16 Re: CamShaft thoughts
    Jul 2012
    North Philly
    Im more worried about passing emissions.
    My car is not an all out race car, it is a daily driver but i do want that sleeper power for whenever i just wanna smash somebody
  17. #17 Re: CamShaft thoughts
    gardner,mass
    So your planning on heads?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  18. #18 Re: CamShaft thoughts
    Jul 2012
    North Philly
    I have heads, custom ported to the specs of basically stage 2-3 heads........
  19. #19 Re: CamShaft thoughts
    Buffalo
    So , because I don't know this answer and I never seen it posted, where do you find cam / emissions data ? Cause until you have that info , it's all a crap shoot
  20. #20 Re: CamShaft thoughts
    May 2008
    Schuyler, NE
    Do you have a tuner?
  1. LF: XP or S1X camshaft
    By WolvesSoulZ in forum Wanted To Buy - Parts
    Last Post: 06-27-2013, 08:01 PM
  2. wtb stock camshaft
    By cwaite2 in forum Wanted To Buy - Parts
    Last Post: 02-28-2012, 06:53 PM
  3. Camshaft?
    By paratroopermatt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 08:16 PM
