Thread: Best front brake upgrade 2000 gtp
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Best front brake upgrade 2000 gtp
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Do you know what the difference between the gxp and f body calipers? What do you have to do to the gxp calipers to fit on a 2000 gtp? Can you put 12.7" gxp rotors with a f body caliper?
  2. #22 Best front brake upgrade 2000 gtp
    No Fbody needs the Fbody 12" rotors. GXP need 12.7 rotors. Now I have no clue what the difference is as far as the caliper/piston/stopping power etc will be between the two. But Keep in mind.. The price of rotors for the GXP are quite a bit more, same goes for pads. Fbody ftw ftw ftw
    04 Comp G.
  3. #23 Re: Best front brake upgrade 2000 gtp
    Jun 2015
    El Paso
    I read on another thread that you can also use corvette calipers. C5 iirc. You just have to tap or sleeve them. However what rotors would I use? And would it for under stock 16 rims?
  4. #24 Re: Best front brake upgrade 2000 gtp
  5. #25 Re: Best front brake upgrade 2000 gtp
    Jun 2015
    El Paso
    The only part I didn't understand is can I use corvette rotors or do I have to use fbody rotors. And 2nd do I have to use corvette brackets or fbody or should I ask there?
  6. #26 Re: Best front brake upgrade 2000 gtp
    Jul 2015
    Jamestown, NY
    Does anyone know if it's worth the extra money for gxp front brakes? Are they a noticeable amount better then the F body brakes?
  1. Front GXP brake upgrade which hoses?
    By Bowtie70SS in forum Brakes/Suspension/Chassis
    Last Post: 08-21-2013, 07:17 PM
  2. Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    By mikes01gtp in forum Brakes/Suspension/Chassis
    Last Post: 04-15-2013, 09:12 PM
  3. F-Body front brake upgrade
    By jlgp2007nc in forum General Grand Prix Discussion
    Last Post: 03-26-2013, 09:26 PM
  4. My 12" front brake upgrade. COMPLETE. Pics
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2010, 06:58 AM
  5. 12" front brake upgrade rim compatibility?
    Last Post: 05-06-2010, 08:22 PM
