Thread: Heat cutting in and out
Results 1 to 4 of 4
  1. #1 Heat cutting in and out
    GTP Level Member Ultra440's Avatar
    Ohio
    The blower motor stops and goes but the electronic readout and buttons always works as it should. It has cut off when hitting a bump on several occasions and usually won't cut back on until another bump is hit.
    Any idears?
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    2003 Park Avenue Ultra- 15% tint, 12" audiobahns, dynamatted trunk and doors, tinted tails, LEDs all around, HID headlights, f body brakes, sd headers, 3.5 pulley and supporting mods
    http://www.grandprixforums.net/my-03...tml#post824292
  2. #2 Re: Heat cutting in and out
    Sounds like the blower itself is dying.
    If you can smack it back into submission when it's turned off, more than likely something inside it is the issue.
  3. #3 Re: Heat cutting in and out
    Ohio
    Ok thanks for the insight
  4. #4 Re: Heat cutting in and out
    Aug 2012
    Stonington, CT
    If the car is high mileage and the fan has had a lot of run time, you may have worn motor commutator brushes. As they wear down, they get to a point where the springs that maintain them in contact with the commutator bars on the shaft of the motor rotor can no longer keep them properly seated. Not sure if the brushes are easily replaced on fan motors of the GPs. When the fan is running while parked, poke around any of the wiring you have access to, try cycling the speed control switch, give the fan motor a few thumps if you can (to be honest I don"t know where it is on my 2001 GP SE yet, it hasn't given me any trouble at 119K).
  1. misfire or cutting out?
    By lewis1952 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-09-2015, 08:02 AM
  2. Help with cutting out 98 GP
    By lgboogie19 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2013, 10:33 PM
  3. 4ch Amp Cutting In and Out
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 05:50 PM
  4. 3.8 n/a running hot and cutting off
    By GTPSHAWTY in forum General Tech Discussion
    Last Post: 12-05-2011, 12:52 PM
  5. Car Cutting out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 04:48 PM
