Thread: My service engine soon bulb is burned out?
Results 1 to 6 of 6
  1. #1 My service engine soon bulb is burned out?
    Sep 2015
    Lansing, Michigan
    02 grand prix gt. 197k
    I believe the ses light is burned out because it never turns on even at initial startup/turning key over. I was able to hook up a scanner and got a code for the light malfunctioning and pulled a map code.
    Anyways, does anyone know which bulb is for the ses, and what type I can use?
    I'd like to order a new bulb online somewhere.
  2. #2 Re: My service engine soon bulb is burned out?
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    In order to replace the bulb, you will need to remove the gauge cluster. The ses bulb is a common 194.
  3. #3 Re: My service engine soon bulb is burned out?
    Jul 2010
    Coquitlam,BC,Canada
    My SES light was burnt out when I bought the car. I blame the PO though. LOL
    As mentioned, the bulb is a 194, and here is the location on the front of the cluster.....
    And I believe this is the location on the rear of the cluster.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: My service engine soon bulb is burned out?
    Sep 2015
    Lansing, Michigan
    thanks. I think the bulb is up higher though.
  5. #5 Re: My service engine soon bulb is burned out?
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Burned bulb is correct, I havn't replaced one, but I would just find a gauage cluster thats close to your milage, but I am a lazy SOB. I almost removed the bulb on one of my cars because SES would always come and go, and it was just a generic misfire, no reason, car wasn't misfiring as I could tell, but just a stupid light that would come and go for no apparent reason, car would drive just fine.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  6. #6 Re: My service engine soon bulb is burned out?
    Jan 2014
    AR
    I'm looking at the back of the cluster off my 02 and Bronco's pic (the red circle) shows the correct location. But its not a 194. It is a bayonet type bulb but very small and in a special socket. The warning lamps are smaller than the illumination lamps which I have bought before. I suggest taking the bulb out and taking it to a local parts store, that what I did when one of the larger bulbs went out. The socket came with the bulb. It wasn't a problem then, but your experience may vary.
  1. P0650 - Check Engine Light issue, bulb ok, low voltage to bulb
    By jasonnovak in forum General Tech Discussion
    Last Post: 10-08-2014, 10:01 AM
  2. service engine soon bulb burnt out
    By Jess Mickle in forum Introductions/Noob Questions
    Last Post: 09-27-2014, 06:32 PM
  3. Radio Display Bulb Burned Out
    By 02NavyBlue in forum General Grand Prix Discussion
    Last Post: 11-06-2013, 11:55 AM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
