Thread: P0650 - Check Engine Light issue, bulb ok, low voltage to bulb
Results 1 to 3 of 3
  1. #1 P0650 - Check Engine Light issue, bulb ok, low voltage to bulb
    Oct 2013
    WI
    I've had a P0650 issue for a while, which is an issue with the check engine light itself which in my case won't light. Clear code and it and it comes back. I took it apart and replaced the bulb, even though the old one tested ok. Still not fixed. From what I read the light is controlled by the PCM which grounds the light to activate it. Here's what I've checked and noticed:
    * Have continuity between CEL bulb and underhood accessory junction box
    * When key in and light should be on, I only see about 3V going to bulb
    * If I test between a pink 12V switched ignition going to the gauge cluster and the CEL ground, I read 12V
    Any thoughts? Not as familar dealing with these ground based circuits, and how/why only 3V gets through to the bulb. Any fixes or other things I should test?
  2. #2 Re: P0650 - Check Engine Light issue, bulb ok, low voltage to bulb
    What year are we talking here?
  3. #3 Re: P0650 - Check Engine Light issue, bulb ok, low voltage to bulb
    Oct 2013
    WI
    Sorry, a 99 GTP
  1. Check Engine Light, Remote Start Issue, and more
    By MidnightGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2012, 02:53 PM
  2. Fog Light Bulb
    By kpowell in forum General Tech Discussion
    Last Post: 04-08-2010, 09:29 PM
  3. telescopic bulb (hid issue)
    By 99prixgt in forum Visual/Body Modifications
    Last Post: 01-16-2010, 06:43 PM
  4. Light bulb question?
    By toolguy in forum General Tech Discussion
    Last Post: 09-10-2009, 10:50 AM
  5. light bulb
    By Myprixxx in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2009, 06:18 PM
