Thread: No start
Results 1 to 6 of 6
  1. #1 No start
    SE Level Member stealth06's Avatar
    Dec 2012
    New York
    I have an 05 GTP that started fine up until two days ago. Drove it to the store and tried to start it to leave and nothing. It doesn't click, there isn't any security warning on the display. After having it towed home I tried starting it again. It would click from the starter but that was it. I put in a new starter and now it will click occasionally when I try to start it but more often then not it is just dead. I have battery voltage down at the starter, but it drops to zero when I hold a volt meter on it when somebody tries to start it. The starter solenoid wire will flash about 1 volt for a split second when trying to crank it but then drops back to zero. The display in the dash does cycle through warnings for low fuel, abs, brake fluid low, and one or two other warnings. None of these things showed up before this no start situation. What should I be checking next?
  2. #2 Re: No start
    Feb 2013
    37.295091, -121.930053
    how old is your battery? and are the connections tight?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: No start
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I think there is a ground wire that goes to the transmission, that if missed causes starting issues
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  4. #4 Re: No start
    Dec 2012
    New York
    Battery is only a about a year old and I cleaned and tightened the connections. I will check the ground wire tomorrow because it is getting dark out now. Thank you for the suggestions. Please keep them coming.
  5. #5 Re: No start
    Dec 2012
    New York
    To anybody who encounters a similar problem, clean the connections on both ends of all the negative battery cables. After doing this the car starts every time. Thanks again for the help guys
  6. #6 Re: No start
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    I bet in 95% of all cases that the battery is shot or the battery cables are badly corroded. I make a point at least once a year to thoroughly clean both the positive and negative cables. Also, I have had to clean up the battery bolts due to rust and corrosion. Glad you got your GP started again.
  1. 06 Base Rough Start with Auto Start
    By jenebo in forum 04+ Specifics
    Last Post: 08-30-2016, 11:24 AM
  2. Installing remote start on non-remote start car
    By GPmanter in forum General Grand Prix Discussion
    Last Post: 01-29-2016, 11:39 AM
  3. 2002 GTP Stalled at Cold Start; Now Won't Start at All
    By Nick8478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2015, 04:51 PM
  4. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  5. 1990 3.1 lit hard start/ no start. fuel pressure prob
    By wadd in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2015, 07:22 AM
