Thread: what's size is the torque bit?
Results 1 to 6 of 6
QuinlanGTP what's size is the torque bit? 10-23-2015, 03:00 PM
Scottydoggs Re: what's size is the torque... 10-23-2015, 03:02 PM
J57ltr Re: what's size is the torque... 10-23-2015, 04:51 PM
BillBoost37 Re: what's size is the torque... 10-23-2015, 08:27 PM
QuinlanGTP Re: what's size is the torque... 10-24-2015, 06:21 AM
1998gt Re: what's size is the torque... 10-24-2015, 12:52 PM
  1. #1 what's size is the torque bit?
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  2. #2 Re: what's size is the torque bit?
    its a E torx or a 12 point may fit. you can use needle nose pliers too, once cracked free they come right out.
  3. #3 Re: what's size is the torque bit?
    GXP Level Member
    Mar 2015
    Tomball
    Don't use a 12 point use a 6 point. usually an 8mm, if you use a 12 point there is a high possibility it will strip.
    Jeff
  4. #4 Re: what's size is the torque bit?
    If you need to borrow tools...holler man.. I'm home tomorrow
  5. #5 Re: what's size is the torque bit?
    Apr 2014
    Chicopee,MA
    You'll be hearing from me! Thanks!
  6. #6 Re: what's size is the torque bit?
    FIREFIGHTER/AEMT
    Dec 2013
    williamsport tennessee
    e torx 3 just removed mine
    1998 grand prix gt 2 door
    2006 ram 2500 cummins diesel 4x4
    2015 NISSAN Rogue SL (wifes ride)
  1. Bolt size and torque spec thread.
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-18-2016, 07:12 AM
  2. Torque rating for wheel bearings ? Axle nut size ?
    By GTP in RTP in forum Brakes/Suspension/Chassis
    Last Post: 02-12-2016, 04:45 PM
  3. Wheel bearing torque? Axle torque?
    By chicagochuck in forum General Tech Discussion
    Last Post: 08-23-2015, 11:59 PM
  4. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  5. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
